remote start on 2008 hummer h3
Troc4434
Copper - Posts: 68
Posted: December 20, 2011 at 6:34 PM / IP Logged
Im going to do an remote start install on my friends 08 hummer h3 which is an manual transmission. first which bypass works well when installed, the xk06
or xk09 bypass? also how do I do the clutch integration since it a manual? thanks
offroadzj
Gold - Posts: 2,043
Posted: December 20, 2011 at 6:44 PM / IP Logged
I prefer the idatalink bypasses with the newer GM's. They seem to do a little better integration. As far as the clutch integration, look for the clutch switch at the clutch pedal. There will usually be 2 switches... one activates as soon as the clutch starts to be engaged that is used for the cruise control; and the other activates when the clutch is fully engaged. That is the switch you want. Test the wires on the connector to see if it is a ground or 12v+ signal. **Make sure to test this wire throughout the ignition sequence (acc, ignition, and start) to make sure it does not change during the start sequence. Then use a relay powered off your status output or starter wire to send the proper signal to the switched side of the connector.
Edit: If I remember correctly, the ADS-ALSL GM from idatalink does not require programming... but I would get verification first.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Troc4434
Copper - Posts: 68
Posted: December 20, 2011 at 7:36 PM / IP Logged
I think im going to go with the xpresskit module because I already had the firmware loader that I hook up to the labtop. also when looking at the xk09 bypass install guide, it does not show trunk,doors,dome light and ect. Will I have to hook these up directly from the 592 to the h2 wire for these to work? or do I have to get another bypass for the door locks? http://www.xpresskit.com/VehicleCompatibility.aspx?p=null&year=2008&make=Hummer&model=H3&ps=1&s=0
Troc4434
Copper - Posts: 68
Posted: December 22, 2011 at 11:04 AM / IP Logged
I think Im going to install it just using relays and resistors instead of the bypass since I still would have to wire all the doors trunk up anyways. is there a diagram anywhere for this? I've only done installs using bypasses.
dasbogie
Silver - Posts: 514
Posted: December 22, 2011 at 11:21 AM / IP Logged
if you search the downloads section of this site for colorado bypass, you will find what you're looking for.
Advanced
Troc4434
Copper - Posts: 68
Posted: December 27, 2011 at 3:50 PM / IP Logged
thanks, Has anybody done the hummers without issues with using the bypass?how much more time consuming is this way? I think If I use a bypass, I still may have to hook up all the car wires to the remote starter is this true?
Platinum - Posts: 7,828
Posted: December 27, 2011 at 7:20 PM / IP Logged
I believe it's just a Colorado Passlock2 immobilizer.  Here is a link to the relays & resistor method  :
http://www.wiringinstructions.com/v2/diagrams200/241%20-%20GM%20Passlock%202004%20Interface.pdf
Does the Hummer have a Factory Alarm?  A full featured bypass might be the best / only way to go.
I have used iDatalink bypass modules ( ADS DL flashed with ADS DL GM4 firmware ) on Colorado's.  Worked flawlessly.
Troc4434
Copper - Posts: 68
Posted: December 27, 2011 at 9:00 PM / IP Logged
oh okay, I have the xkloader for the xpresskits. I think If I use the expresskits xk09 I still would have to hook up all the car wires. I dont have the loader for the idatdalink. I would have to by that
Posted: December 27, 2011 at 9:16 PM / IP Logged
Yes, the XK09 only does the bypass function.  All the other wires would have to be run.  There is a pre-loaded iDatalink bypass module available for the H3.  Check out the ADS ALSL GM module at :  http://store.idatalink.com/index.php?l=product_detail&p=141
shortcircuit161
Silver - Posts: 556
Posted: December 30, 2011 at 10:40 AM / IP Logged
I did two 2007 H3 Hummers last winter with Avital 4103LX units with the Idatalink ADS-ALSL GM bypasses connected W2W. Everything worked great for two days. And then the customers called me (mother and daughter) and stated each truck went into tamper lockout. I thought bad connection so I redid everything but still the same problem. Recently, Idatalink has updated their website to state the relay and resistor method work best on the H3 models. 2007-2009 are the same setup. I would strongly recommend the relay and resistor method. The trucks have been remote starting great since. Good Luck on your install!!
Read below per the Idatalink website:
H3, Colorado & Canyon 2008-2009-2010 Passlock Tamper Mode: Please read the following before installing.
Passlock is not covered by the module on these vehicles because the BCM doesn't adapt well to external passlock modules.
Vehicle BCM internal power fluctuation which occurs in many different circumstances negatively affects external passlock bypass reliability. When such fluctuation occurs the risks the vehicle going in tamper mode during remote start are high. The bypass module provides you a highly precise (±0.002v) passlock value, the module will not fluctuate when the BCM does which can result on the BCM and module not being on the same comparison scale. If such situation occur the vehicle will probably go in tamper mode.
The IPC reference wire must be used as the sole Passlock reference in these vehicles to avoid Tamper Mode.
We recommend using relays and very accurate resistors on these specific Models/Years. (the Module will still take care of the PK3 immobilizer, OEM alarm and doorlocks).
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
