00' deville R/Startand keyless
mxxmikexx
Silver - Posts: 796
Posted: April 30, 2003 at 3:47 PM / IP Logged
ive got this car coming in a few days for a remote start, with keyless entry and trunk release, just wanted to know if anyone had any hints/tricks on the install. from what i know so far i need a GMDL2 for the doorlocks, and the car has passkey3, where can i get trunk release and tach?
Chris Luongo
Platinum - Posts: 3,746
Posted: April 30, 2003 at 9:36 PM / IP Logged
That car is a little time consuming, but it's not nearly as hard as some of the tech sheets would make it out to be. I'll give you all my shortcuts, and then some regular tech information at the end.
-If you want a strong source of constant power, there's a thick orange wire in the driver's kick panel that is suitable.
-You don't necessarily need a module to do locks. The locks can be had as negative trigger, but you have to go inside the door.
Disarm is in the door too---there are two similar-looking light green wires---one is for the power mirrors---so test carefully so you get the right wire the first time.
-I've never had to power up the brown second accessory (radio) wire for remote start.
-Parking lights is BROWN / white, negative, at the switch---I've never bothered chasing down the DIM module.
-Trunk release is black, negative, at the release switch on the driver's side of the dash. Fuel door release is in there too if you look for it---I think it's pink?
-Also, don't forget to set up your unit to disarm the factory alarm while the trunk is being opened.
-Furthermore, I think an extended pulse to the disarm wire might roll down some of the windows. I'm not sure of this, though. Put the key in the driver's door, hold it to the Unlock position, and see what happens.
-Tach isn't too hard. The coil pack is easily found at the top-rear of the motor, with four plugs, two large and two small. I know tach is inside one of the driver's-side plugs, but I forget which one.
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|orange or orn/blk *1|+ |ignition harness            |
|          STARTER|purple or yellow    |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|white               |+ |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
| SECOND ACCESSORY|brown               |+ |ignition harness            |
|       POWER LOCK|RED / black           |- |drivers door lock switch    |
|     POWER UNLOCK|ORANGE / black        |- |drivers door lock switch    |
|       LOCK MOTOR|gray               |   |drivers door module *2      |
|     UNLOCK MOTOR|tan                 |   |drivers door module *2      |
|    DISARM DEFEAT|tan                 |   |passenger door module *3    |
| PARKING LIGHTS +|do not use          |   |                            |
| PARKING LIGHTS -|BROWN / white        |   |DIM module *4               |
|       HEADLIGHTS|white               |- |DIM module *4               |
|     DOOR TRIGGER|*5                  |- |*5                          |
| DOME SUPERVISION|gray               |- |underdash light             |
| TRUNK/HATCH PIN|ORANGE / black        |- |trunk light                 |
|TRNK/HTCH RELEASE|BLACK/ white        |- |under the rear seat *6      |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |- |drivers door module *2      |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|PURPLE / white        |   |ign. coil on top of motor   |
|      SPEED SENSE|GREEN / WHITE        |   |cruise control module *7    |
|       BRAKE WIRE|white               |+ |low in drivers kick        |
|     HORN TRIGGER|black               |- |DIM module *4               |
|           WIPERS|white               |+ |DIM module *4               |
| LF WINDOW UP/DN|dk. blue - brown    |A |drivers door module *2      |
| RF WINDOW UP/DN|dk. blue - brown    |A |passenger door module *3    |
| LR WINDOW UP/DN|dk. blue - brown    |A |LR door module              |
| RR WINDOW UP/DN|dk. blue - brown    |A |RR door module              |
| SUN RF OPN/CLOSE|dk. grn - lt. grn   |A |sunroof motor *8            |
|   SUN ROOF LIMIT|red                 |- |sunroof motor *8            |
|        RADIO 12V|orange              |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
| RADIO ILLUMINATE|yellow/black        |*9 |radio                      |
Notes:
Note: This vehicle is equipped with the pass-key III immobilizer. Use DEI part number 555U to bypass. Note: The fuel door release is white, negative trigger, located under the rear seat at the fuse/relay block *1 This is a low current 12V source that should not be used to drive any high current positive circuits. *2 The drivers door module is located above the speaker in the drivers door. *3 The passengers door module is located above the speaker in the passenger door. *4 The DIM module is located just in front of the blower motor near the passenger kick. It has three connectors that all exit out of the bottom of the module. All wires are located in the ceter plug except for the horn trigger wire which is located in the right side plug. *5 The drivers door trigger wire is tan at the drivers door module, and the other door triggers are dk. blue at there respective door modules. *6 At the fuse/relay block. *7 The cruise control module is located under the hood on the drivers side inner fender. *8 The sunroof motor is located to the rear of the sunroof towards the top center of the rear window. *9 Power varies with the interior light volume.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
