remote start problem, 97 honda crv
hillco148
Posted: January 02, 2012 at 10:05 PM / IP Logged
HI All! Have a problem and see if you can help.
I have a 97 honda crv auto. it has a viper 300+ alarm and i'm adding a auto starter from auto command m#25622.
i took out the starter kill relay. i went and connected all wires needed to start the car.
when i remote start it the ignition wire have no power. (test light on blk/yel)
(it cranks)
remote works with auto starting
it only remote start when i leave the key in "on" position. (ignition have power)
there only 5 wire from the key ignition
blk/yel,
blk/white,
WHITE/ blk,
wht, &
yellow.
am i missing some thing here? why is there no power when the auto start kicks.
any help would be great!
the wire i connected on the auto command:
brake pedal
tach dist
constant
starter
ignition (problem)
ignit output to viper ignit input)
RED / wht wire to viper aux output.
LInk to auto command 25622:
http://www.readyremote.com/pdf/manuals/25622.pdf
link to viper 300x alarm:
http://www.directeddealers.com/manuals/ig/viper/N432V.pdf
tedmond
Gold - Posts: 4,610
Posted: January 02, 2012 at 11:34 PM / IP Logged
did you power up red, RED / white, RED / black?
Ted
Compustar Expert
hillco148
Posted: January 03, 2012 at 12:06 AM / IP Logged
The only wire connected from the viper to auto command is the wht/blu wire (viper)
 to RED / wht wire (auto command).
I put a test light on the auto command unit.
When auto start is push
There light on constant 12v
Light on starter when cranking
But no light on ignition wire blue??
Did I miss some wires?
Posted: January 03, 2012 at 2:57 AM / IP Logged
Is there a by-pass missed here as well?
Posted: January 03, 2012 at 3:02 AM / IP Logged
Oh sorry about that, I saw it as an 07.
Effing senile dementia.
Actually Ted, 2 x pink and one red.
Posted: January 03, 2012 at 3:09 AM / IP Logged
Still wrong, 2 x pink!
N.B. Assuming this is an auto box, there's seemingly no NSS provision.
offroadzj
Gold - Posts: 2,043
Posted: January 03, 2012 at 6:07 AM / IP Logged
What constant wires did you connect from the remote start unit? It sounds like you don't have the 12v input for the ignition relay connected to a good 12v source which would explain why you have no voltage on your ignition wire.
Edit: Oh sorry, I see now that is what Howie meant by 2x pink... haha. Yea, what they said, both Pink wires need to be connected to a 12v constant source (White wire in vehicle). Also make sure you are activating the ignition wire (BLACK / YELLOW) and both accessory wires (Yellow & WHITE/ Black).
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
hillco148
Posted: January 03, 2012 at 10:14 AM / IP Logged
I see... i will try that when i get home tonite.. thanks for the advise.. mak.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
