2008 hyundai tuscon, cool start rs-3
dayne97
Member - Posts: 9
Posted: January 04, 2012 at 11:26 PM / IP Logged
Installing a Cool Start RS-3 into a 2008 Hyundai Tucson with a OFA 30 bypass.
The bypass module had part 1 of the klon programming but it is not active I. the vehicle no led or anything.
The truck will crank but not fire everything else works. Any idea as to why the module won't fire up?
I should note that all the wiring.info I had was wrong to begin with sk my data wire is suspect, they have it over in the passenger kick panel but the info in the manual is co.conflicting one place it says 6 pin the other it says 10. Would the data wire not be located on the diagnostic plug?
Thanks for the help
Gavin
dayne97
Member - Posts: 9
Posted: January 05, 2012 at 1:56 PM / IP Logged
Installing a cool start rs3 in a 2008 Tucson, door locks etc. Work but truck only starts when key is in ignition, what am I missing? I'm sure the solution is simple but I've hit.the wall.
Also install instructions say this needs a bypass module but tech guy says it doesn't.
Thack79
Silver - Posts: 526
Posted: January 05, 2012 at 1:59 PM / IP Logged
Not sure who tech guy is but if its only remote starting with the key in the ignition then you need a bypass module
