556uw
asdf11
Member - Posts: 6
Posted: January 07, 2012 at 12:38 PM / IP Logged
I am installing a 556uw for the first time on a HHR and the ring is almost twice the size of the cylinder.  Do I have to shorten the loop or can I just fold over the extra after I cover the circumference of the cylinder?
I also have the factory thing right behind the trim piece.  Can I put the loop behind the factory thing?
Platinum - Posts: 7,828
Posted: January 07, 2012 at 1:03 PM / IP Logged
If they 556UW has the pre-formed ring, place it around the ignition switch and tie wrap the excess out of the way & securing it in place.
The correct placement is in front of the antenna right, right behind the cover as you currently have it.
enice
Silver - Posts: 857
Posted: January 07, 2012 at 9:47 PM / IP Logged
If you are talking about the Chevy HHR then the 556U is no the bypass you need.
Twelvoltz
Platinum - Posts: 2,384
Posted: January 08, 2012 at 7:38 AM / IP Logged
The 556U will work fine when combined with relays and resistors in the HHR. There are better options for bypass in the HHR but that does not mean the 556U wouldn't work. For example the ADS-AL CA with the GM ring works without having to lose a key and handles the MUX circuit so there's no need for additional relays and resistors.
asdf11
Member - Posts: 6
Posted: January 08, 2012 at 9:01 AM / IP Logged
do you know where i can find a diagram with relays and resistors?
enice
Silver - Posts: 857
Posted: January 08, 2012 at 1:49 PM / IP Logged
If installing a 556 is difficult then maybe the 556 is not the bypass to use with this vehicle. The ADS ALCA is far better. That is really what i wanted to say.
Posted: January 08, 2012 at 4:09 PM / IP Logged
Here is some info for the HHR bypass :
http://documents.audiovox.com/700812.pdf
http://documents.audiovox.com/700054.pdf
Agree with fellpw forum members.  An iDatalink bypass module like the ADS-ALSL GM will make life easy.
http://store.idatalink.com/index.php?l=product_detail&p=141
asdf11
Member - Posts: 6
Posted: February 16, 2012 at 6:56 PM / IP Logged
Does anyone have pictures of the 556u ring installed?  I can remote start the car with the key in the ignition.  The relay in the 556 box clicks so I think it is working.
556uw -- posted image.
tedmond
Gold - Posts: 4,610
Posted: February 16, 2012 at 7:34 PM / IP Logged
try placing it on the black ring, securing with some double sided tape
Ted
Compustar Expert
Mike M2
Platinum - Posts: 2,652
Posted: February 17, 2012 at 6:21 AM / IP Logged
It starts with the key in because it sees the resisted values. You need to add the relays/resistors.
Personally i would never do one without an Idatalink module...
Mike M2
Tech Manager
CS Dealer Services
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
