04 colorado, remote start
edgacost
Posted: January 09, 2012 at 12:26 AM / IP Logged
Hey ive been to wire a aftermarket generation remote start to my 2 door 04 colorado just the remote start an the lock and unlock im not intrested in the alarm that came with the kit..but havent had any luck with the wireing has any one wired a remote start to this spacific truck that can help me ?????
Posted: January 09, 2012 at 1:00 AM / IP Logged
What make remote start and what have you wired to where?
offroadzj
Gold - Posts: 2,043
Posted: January 09, 2012 at 6:05 AM / IP Logged
That truck is not impossible, but it is a little more troublesome/difficult than most. Get yourself a data bypass and safe a lot of hassle. Idatalink.com is your friend. Any of their orange colored boxes are pre-flashed bypasses that will be able to be used without flashing the firmware.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
edgacost
Posted: January 09, 2012 at 8:50 PM / IP Logged
I have a aftermarket generation model no aga1201 its the keyless entry vehicle security system plus remote start... And i did do my resech i read the manual and did my reserch online.. Ok let me tell u what ive done so far i connected the starter wire cable to the pljx omega bypass and the ignition to the white green cable thats in the ignition switch harness ..the accessory output to the white red cable frome the ignition harness...the second ignition wire to the pink ignition wire frome the plxj...and the first ignition wire to the white green cable from the ignition harness....and all the power wires to a constant 12v wire that comes frome the battery o and the pink white from the pljx to the ignition cylinder and the blue cable also from the pljx to the data ecm sideand thats about it
Posted: January 10, 2012 at 2:25 AM / IP Logged
I think you're in a world of trouble here.
DEI lists TWO starter wires and ONE ignition, also have you connected tach, hood switch etc. etc.
edgacost
Posted: February 19, 2012 at 9:43 PM / IP Logged
sry i ran into a problem over here but hey im still having a problem with wireing this thing
offroadzj
Gold - Posts: 2,043
Posted: February 19, 2012 at 10:04 PM / IP Logged
make up a quick list of all of your connections so I can take a better look at what you have.
As far as ignition wires goes, here is what you should have:
12v constant - Battery + (fused at 30amp)
Starter - Violet (starter input) wire on PJLX
Ignition - WHITE/ Green at ignition switch
* Connect Pink ignition input from PLJX to the Ignition wire off the remote starter
Accessory - WHITE/ Red at ignition switch
PLJX Wiring:
Brown - status output (ground out when running) from r/s
Blue - BCM side of cut white or WHITE/ blue Data wire
Violet - Starter wire from r/s
Pink/White - Switch side of cut white or WHITE/ blue Data wire
Pink - Ignition wire from r/s
Red - 12v constant (fused)
Black - chassis ground
It sounds like by connecting the PLJX only to the 2nd ignition output of the remote starter, it cannot sense the vehicle ignition by the key, which will not allow it to program to the vehicle.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
edgacost
Posted: February 19, 2012 at 10:27 PM / IP Logged
what i wrote on jan 9 is whats still wired in the truck ......ok so the first ignition wire thats connected to the truck harness is not working
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
