remote start 2008 honda crv
ibpowers
Posted: January 16, 2012 at 9:14 PM / IP Logged
Greetings,
Can anyone provide wiring info for remote starter in a 2008 Honda CRV?
Thank you
Ibpowers
offroadzj
Gold - Posts: 2,043
Posted: January 16, 2012 at 9:18 PM / IP Logged
12volts      white (50A)      +      ignition switch, brown 6 pin plug, pin 3
Starter      yellow      +      ignition switch, brown 6 pin plug, pin 1
Second Starter      N/A
Ignition      blue      +      ignition switch, brown 6 pin plug, pin 6
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange      +      ignition switch, brown 6 pin plug, pin 4
Second Accessory      red      +      ignition switch, brown 6 pin plug, pin 5
Keysense      gray      -      ignition key switch, green 7 pin plug, pin 1
Power Lock      blue      -      driver kick, door harness
Power Unlock      gray      -      driver kick, door harness
Lock Motor      pink      5 wire      fuse box, green 42 pin plug, pin 21
Unlock Motor      gray      5 wire      driver kick, door harness
Parking Lights+      red      +      above driver kick, blue 18 pin plug, pin 1
Parking Lights-      blue      -      headlight switch, 12 pin plug, pin 11
Hazards      purple      +      hazard switch, green 6 pin plug, pin 5
Turn Signal(L)      orange      +      fuse box, green 42 pin plug, pin 40
Turn Signal(R)      brown      +      fuse box, green 42 pin plug, pin 39
Reverse Light      brown      +      fuse box, green 42 pin plug, pin 15
Door Trigger      green      -      fuse box, green 42 pin plug, pin 37
Dome Supervision      purple      -      right of fuse box, white 20 pin plug, pin 19
Trunk/Hatch Pin      pink      -      fuse box, green 42 pin plug, pin 36
Hood Pin      lt. blue      -      fuse box, blue 21 pin plug, pin 9
Trunk/Hatch Release      white (rear handle switch)      -      fuse box, green 42 pin plug, pin 13
Power Sliding Door      N/A
Factory Alarm Arm      pink (driver door key cylinder)      -      driver kick, door harness
Factory Alarm Disarm      brown (driver door key cylinder)      -      driver kick, door harness
Disarm No Unlock      see factory alarm disarm
Tachometer      NOT yellow/black      ac      any fuel injector
Wait to start      N/A
Brake Wire      lt. green      +      fuse box, green 42 pin plug, pin 34
Parking Brake      purple      -      parking brake switch
Horn Trigger      orange      -      horn switch, yellow 20 pin plug, pin 1
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:     Category:
Immobilizer Bypass     Required:
Yes     Type:
Transponder
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
ibpowers
Posted: January 17, 2012 at 8:23 AM / IP Logged
Thank you Kenny!
tedmond
Gold - Posts: 4,610
Posted: January 17, 2012 at 8:55 AM / IP Logged
easy vehicle for a start only. if you are doing an alarm as well, consider using an idatalink ads-al-ca or fortin evo CAN or ALL.
what are you using as your bypass module?
Ted
Compustar Expert
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
