python 460max starter kill
airbur
Posted: March 12, 2012 at 12:04 PM / IP Logged
Howdy,
I have installed the above alarm in my 1970 Bronco. It comes with a starter kill relay pre-wired with the alarm and uses a 610T 5 pin relay. I have wired it exactly as the install manual shows and the alarm works fine other than starter kill.
I am able to start the vehicle with the alarm armed. I split the starter wire that runs from the kit switch to the starter solenoid and wired the relay. If I pull the relay, I cannot start the vehicle, so I'm fairly sure I have the right wire. It's the RED / blue here:
http://seabiscuit68.tripod.com/images/68-71ignition-color.gif
I tried another relay, same problem. Any help would be appreciated.
Thanks.
airbur
Posted: March 12, 2012 at 12:32 PM / IP Logged
That should be "ignition switch" not "kit switch".
tedmond
Gold - Posts: 4,610
Posted: March 12, 2012 at 9:46 PM / IP Logged
85 - ground when armed from viper
86 - ignition 1
87a - starter wire key side
30 - starter wire car side
Ted
Compustar Expert
