1991 Ford Mustang
BWhitie
Posted: May 04, 2003 at 11:36 AM / IP Logged
I have a 91 Ford Mustang GT with the power options (locks and windows) with a Viper alarm installed in it when I bought the car off of the previous owner.  I no longer want that system in my car and have no experience with car security and or alarm systems.  Is there any wiring diagrams or etc available to show me a schematic of the wires and hook ups for the system so I am aware of what I am doing when pulling out the old system and installing a new one.
bw
10nesne1
Silver - Posts: 284
Posted: May 04, 2003 at 1:52 PM / IP Logged
If you have no experience than you should bring it to shop. It will save you lot of headache.
Good luck........
Platinum - Posts: 12,488
Posted: May 04, 2003 at 10:05 PM / IP Logged
|              12V|yellow              |+  |ignition harness            |
|          STARTER|RED / blu or wht/pink |+  |ignition harness            |
|         IGNITION|RED / green           |+  |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|gray / YELLOW         |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |5wi|either kick panel           |
|     POWER UNLOCK|pink/green          |5wi|either kick panel           |
| PARKING LIGHTS +|brown               |   |light sw or dr. kick        |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|RED / yellow          |+  |at light switch             |
|     DOOR TRIGGER|BLACK/ blue          |+  |at pin switch in kick       |
|TRNK/HTCH RELEASE|purple / YELLOW       |+  |at switch                   |
|       TACHOMETER|tan / YELLOW          |   |coil or diagn. plug *1      |
|       BRAKE WIRE|RED / lt. green       |+  |brake pedal switch          |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column             |
|           WIPERS|BROWN / white *2      |+  |at switch harness           |
|  LF WINDOW UP/DN|wht/blk - yellow    |A  |in drivers door             |
|  RF WINDOW UP/DN|wht/yel - tan/blu   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|yel/blu - RED / blu   |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |in drivers door or dkp      |
Notes:
*1 Plug at driver's front corner of engine on 4 cyl, coil at driver's shock tower on 8 cyl.   *2 This is for low and high speed. For intermittent there is a dark green which pulses. Add the two signals together with diodes.
