2006 equinox, viper 5704, dball
mullethead
Member - Posts: 18
Posted: July 25, 2012 at 9:39 PM / IP Logged
Vehicle 2006 Chevrolet Equinox W/ Pioneer Radio Upgrade
Installed Kenwood DVD
ASWC AXXESS
RAP Adapter
Listed in case there are any conflicts. Radio and all features functioning.
Viper 5704
Xpresskit DBALL
flashed with 401.gm5_1.06.01 using Xloader 2 (XPRESS VIP3 Program)
Install Type 6
Would Like to use d2d for the additional features over w2w listed in the features menu.
DBALL Connections
purple / YELLOW to diagnostic connector pin2
BLACK/ white to driver door trigger grey/black
GREEN/ black not used for passlock1
violet/green yellow wire @ ignition
violet/brown yellow wire @ ignition
pink(+)ignition input to Viper Pink 200ma Ignition 1 Output H2/10
In the forum, there are notes to hook this directly in line with the Pink ignition harness?
Viper 5704
Main Harness 6 pin Connector
H1/1 Red (+)12 vdc constant input Battery constant
/2 Black(-) chasis ground        ground to chasis
/3 Brown Siren Output(+)   (+)Red Siren
/4 WHITE/ Brown Parking Light Isolation Wire     Not Used
/5 White Parking Light {fuse polarity (-)}     BCM Grey B3 Lt Blue
/6 Orange GWA Output        Not Used
Door Lock 3 Pin Connector
1Blue D2D
2 Empty
3Green D2D
Remote Start 10Pin Heavy Gauge Conector
H3/1 Pink Ignition Output Pink Ignition Switch Pin F
/2 RED / White(+) Fused 30A Ignition 2/ Flex Relay    Ign Switch Pin A
/3 Orange(+) Accessory Output      Ign Switch Orange Wire
/4 Violet Not Used
/5 Green Not Used
/6 Red Not Used
/7 Pink/White (+) Ignition 2/Flex Relay Out   Brown
      (set as accessory 2 in Menu 3 Remote Start)
/8 Pink/Black             Not Used
/9 RED / Black(+) fused (30A) Accessory Not Used
/10 No Connection
Auxillary/ Shutdown/ Trigger Harness
H2/1 Pink/White        Not Used
/2 BLACK/ White   ground to chasis
/3 Blue/White Second Status D2D
/4 GREEN/ Black OEM Alarm Disarm     D2D
/5 RED / White Trunk Release Output     N/A
/6 Green (-) Door Trigger Input     D2D
/7 BLACK / YELLOW Dome Supervision     BCMPink B1 White
/8 BROWN / Black Horn Honk Output     BCMPink A3
/9 Dark Blue (-) 200MA status out     ???
/10 Pink        Wired to D2D
/11 WHITE/ Black (-)200MA Aux3 Out     N/A
/12 Violet(+) Door Trigger Input     D2D
/13 WHITE/ Violet 200MA Aux 1 Output      D2D
/14 Violet/Black 200MA Aux 2 Output     N/A
/15 ORANGE / Black 200MA Aux 4 Output     N/A
/16 Brown(+) Brake Shutdown (+) LT Blue Brake Pedal
/17 Grey Hood Pin Input N/A
/18 Violet / YELLOW 200MA Starter Out     N/A
/19 Blue Trunk Pin/ Instant Trigger     D2D
/20 Grey/Black Diesel Wait To Start     N/A
/21 WHITE/ Blue RemoteStart/TurboTimer     N/A
/22 Orange 200MA Accessory Input     N/A
/23 Violet/White Tach Input D2D (tach in menu 3 settings)
/24 (-)200MA oem Alarm Arm Output     D2D
The Problem I am experiencing is related to the Pink/White Ignition 2 Flex Relay Output set as accessory.
When connected it is setting off my passlock2 alarm. Ignition will not start car. DBALL will not program, etc.
Disconnect and the programming functions for DBALL, car starts as if alarm is not there. All alarm functions working.
Just not remote start. Alarm brain defective?
Great website! I have used it for massive amounts of information, but am hoping for a little assistane from folks a lot
brighter than myself. From reading the thousands of posts I read before ordering the parts, mapping out the install, etc.
A few members shine brighter than others.
Thanks again if anyone has any thoughts.
Platinum - Posts: 7,828
Posted: July 25, 2012 at 10:02 PM / IP Logged
Here are a few corrections...
H3/2 RED / White(+) Fused 30A Flex Relay          RED / White @ Ignition Switch
H3/3 Orange(+) Accessory Output           Ign Switch Orange Wire
H3/4 Violet              Not Used
H3/5 Green             Not Used
H3/6 Red      Not Used       RED / White @ Ignition Switch
H3/7 Pink/White (+) Flex Relay Out           Brown      *** set for ACC2
H3/8 Pink/Black      Not Used
H3/9 RED / Black(+) fused (30A) Acc            Not Used         RED / White @ Ignition Switch
H3/10 No Connection
Posted: July 25, 2012 at 10:16 PM / IP Logged
The DBALL Pink (+) Ignition input wire ( 10 Pin connector ) must go to the Viper H3/1 (+) Pink wire that then continues to the vehicles (+) Pink wire at the ignition switch.  You have it connected to the Vipers (-) 200ma Igntion output on H2/10, I think.
mullethead
Member - Posts: 18
Posted: July 26, 2012 at 1:27 AM / IP Logged
Thanks for the help. Spent a few minutes adding the two additional wires. Solved the pass lock being triggered. DBAll programmed no problem. Checked Viper settings. Remote start did not fire but the diagnostic said low rpm. Will wire direct to Viper tomorrow morning before work and hope for the best .
Posted: July 26, 2012 at 4:14 AM / IP Logged
Yes, I have heard that DBALL tach does not work too well thru Data.  Try direct wire between the units and re-learn the tach.  If thatt fails, go directly to a F.I.
Posted: July 26, 2012 at 7:36 AM / IP Logged
Here is another possibility.  I believe the 2006 Equinox has built in
anti-grind and "one touch starting" ( just a quick turn of the key to
the START position and back to ON will start the engine ).  If that is
the case, you can set the Viper to Engine Checking Off and a Fixed Crank
time of 1.2 seconds in Menu 3 and you will be fine.
