2012 ford edge rear defrost wire
je3169
Copper - Posts: 73
Posted: August 02, 2012 at 4:25 AM / IP Logged
Hey guy's wondering if you can help I am installing a R/S in a 2012 Ford Edge and need to tap into the rear defrost anybody know what color wire and where I can tap into?
Thanks John
Platinum - Posts: 7,827
Posted: August 02, 2012 at 5:08 AM / IP Logged
Think it's the same as 2011.  Here is 2011 Ford Edge info from Omega :
Rear Defrost     WHITE\ORANGE (- LATCHED)          @ BLACK 30 PIN JUNCTION CONN NEAR STEERING COLUMN, PIN # 5
je3169
Copper - Posts: 73
Posted: August 02, 2012 at 5:11 AM / IP Logged
Thanks for the quick response I will give it a shot.
Thanks John
je3169
Copper - Posts: 73
Posted: August 03, 2012 at 3:22 PM / IP Logged
Would this be at the SJB I am not finding a 30 pin connector at the steering column of if you have any pic's of the connector that would help.
Thanks John
Posted: August 03, 2012 at 5:36 PM / IP Logged
Sorry, no pictures.  Haven't done a 2012 Edge yet to be able to verify this wire.  From the description it doesn't sound like a SJB connector.  Perhaps another forum member can assist with first hand info on a 2012.
je3169
Copper - Posts: 73
Posted: August 03, 2012 at 10:48 PM / IP Logged
I have 2 big connectors behind the knee panel under the steering column checked all the WHITE/ orange wires in there (4 of them) I will talke a pic tomorrow and post.
Thanks John
chev104275
Gold - Posts: 1,436
Posted: August 04, 2012 at 6:43 AM / IP Logged
Have you checked behind the HVAC panel ?
je3169
Copper - Posts: 73
Posted: August 04, 2012 at 3:47 PM / IP Logged
No i was hoping to pick it up in a easier place so i would not have to remove the screen and take apart the whole dash but it looks like i might have to.
Thanks John
je3169
Copper - Posts: 73
Posted: September 21, 2012 at 12:37 AM / IP Logged
Bump.
tommy...
Gold - Posts: 1,901
Posted: September 22, 2012 at 10:56 AM / IP Logged
2012 Ford Edge (Smart Key)     DirectWire 2.0 Vehicle Information
Remote Start
Item     Wire Color     Polarity     Wire Location
12 Volts     GREEN/ red (15A)     +     start/stop switch, 6 pin plug, pin 4
Second 12 Volts     red (120A)     +     BCM, black 1 pin plug (G), pin 1
The BCM (Body Control Module) is the dash fuse box, in the driver kick.
Starter     BROWN / purple (SS1)     +     start/stop switch, 6 pin plug, pin 1
Second Starter     yellow/orange (SS2)     -     start/stop switch, 6 pin plug, pin 6
Ignition     gray/brown (for ignition sense only)     +     BCM, gray 10 pin plug (E), pin 10
Second Ignition     N/A
Third Ignition     N/A
Accessory     WHITE/ blue (for accessory sense only)     +     BCM, brown 26 pin plug (F), pin 11
Second Accessory     N/A
Third Accessory     N/A
Keysense     N/A
Data Bus     WHITE/ blue (data), yellow/gray (clock)     data     Backup Transceiver in center console, 5 pin plug, pins 3 and 4
Can Bus High     gray/orange (MS CAN); WHITE/ blue (HS CAN)     data     data link connector, black 16 pin plug, pins 3 and 6
Can Bus Low     PURPLE / orange (MS CAN); white (HS CAN)     data     data link connector, black 16 pin plug, pins 11 and 14
Can Bus Sw     N/A
Power Lock     blue/green     -     driver kick or BCM, gray 26 pin plug (C), pin 6
Power Unlock     yellow/purple     -     driver kick or BCM, gray 26 pin plug (C), pin 8
Lock Motor     gray/brown     5 wire     driver kick, door harness
Driver Unlock Motor     blue/green     5 wire     driver kick, door harness
Parking Lights (-)     (HS CAN)
Parking Lights (+)     yellow/blue     +     BCM, gray 10 pin plug (E), pin 6
Hazards     BROWN / yellow     -     BCM, black 52 pin plug (B), pin 32
Turn Signal (Left)     blue/green (F); gray/orange (R)     +     BCM, brown 26 pin plug (F), pin 8; gray 26 pin plug (C), pin 14
Turn Signal (Right)     yellow/purple (F); GREEN/ orange (R)     +     BCM, brown 26 pin plug (F), pin 7; gray 26 pin plug (C), pin 15
Headlight     BROWN / blue (L); blue/green (R)     +     BCM, gray 10 pin plug (E), pins 2 and 1
AutoLights     (HS CAN)
Reverse Light     blue/white     +     driver kick or BCM, black 32 pin plug (D), pin 13
Left Front Door Trigger     GREEN/ purple     - N.C.     driver kick or BCM, gray 26 pin plug (C), pin 9
Right Front Door Trigger     white     - N.C.     driver kick or BCM, gray 26 pin plug (C), pin 5
Left Rear Door Trigger     green     - N.C.     driver kick or BCM, gray 26 pin plug (C), pin 20
Right Rear Door Trigger     yellow     - N.C.     driver kick or BCM, gray 26 pin plug (C), pin 21
Dome Supervision     gray/purple (dome lamp); purple (puddle lamp)     +     BCM, gray 12 pin plug (A), pin 1; gray 26 pin plug (C), pin 1
Trunk/Hatch Pin     gray/orange     - N.C.     driver kick or BCM, gray 26 pin plug (C), pin 19
Rear Glass Pin     N/A
Hood Pin     blue/orange     - N.C.     BCM, brown 26 pin plug (F), pin 2
Trunk/Hatch Release     brown (rear handle switch)     -     driver kick or BCM, gray 26 pin plug (C), pin 23
The BCM (Body Control Module) is the dash fuse box, in the driver kick. On vehicles with power liftgate, the open/close is gray / YELLOW (-) at the power liftgate release switch, 6 pin plug, pin 6.
Trunk Release Motor     GREEN/ brown     5 wire     driver kick, harness to rear
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     PURPLE / green and YELLOW /GREEN (w/driv door keypad)     both -     driver kick, door harness
Factory Alarm Disarm     see disarm no unlock
Disarm No Unlock     Transponder and ignition
Trunk Alarm Shunt     N/A
Tachometer     grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh     ac     any fuel injector, black 2 pin plug, pin 1
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     PURPLE / green     +     driver kick, harness to rear
Rear Defroster     WHITE/ orange     - latched     junction connector near steering column, black 30 pin plug, pin 5
Mirror Defroster     same as rear defroster
Left Front Heated Seat     (MS CAN)
Right Front Heated Seat     (MS CAN)
Speed Sense     BROWN / green (3.5L or 3.7L)     ac     Powertrain Control Mod on pass firewall, black 50 pin plug, pin 25
On 2.0L models, it is BROWN / green at the Transmission Control Module next to the battery, 60 pin plug, pin 51.
Brake Wire     PURPLE / white     +     brake switch or BCM, black 52 pin plug (B), pin 28
Parking Brake     WHITE/ purple     -     parking brake switch or BCM, gray 26 pin plug (C), pin 7
Horn Trigger     PURPLE / green     -     horn switch or BCM, black 52 pin plug (B), pin 33
Wipers     (LIN bus)
Memory Seat 1     PURPLE / white     -     memory set switch, 8 pin plug, pin 2
Memory Seat 2     yellow     -     memory set switch, 8 pin plug, pin 6
Memory Seat 3     N/A
M.E.C.P & First-Class
