viper 350 plus strange problem
benelectrical
Copper - Posts: 59
Posted: August 18, 2012 at 3:29 AM / IP Logged
hello all. thanks for having a look at this thread.
I have fitted alot of viper alarms and alarms in general and this is the first time iv had a problem later down the track. 2 months ago i fitted a 350plus two way alarm. as said its been in their for 2 or more months and no problems.
 basically the alarm started going off randomly while car is running. the unlocking and locking of the alarm / central locking. but the alarm stays on, i have a bitwriter tool and reset the alarm and the alarm still has the same problem. is this a fairly common problem?
benelectrical
Copper - Posts: 59
Posted: August 18, 2012 at 3:30 AM / IP Logged
also the parkers flash at the same time.
Posted: August 18, 2012 at 9:42 AM / IP Logged
Have you wired the yellow to the ignition?
benelectrical
Copper - Posts: 59
Posted: August 18, 2012 at 10:38 AM / IP Logged
yep yellow connected to ign. the strange thing is it has been working fine for 3 or more months. also this is on my own car so definatly hasnt played up since. alarm adds ons are
domelight supervision - channel 3 output to acc - channel to for boot solonoid
any ideas
Posted: August 18, 2012 at 11:15 AM / IP Logged
Make sure you haven't a dry solder joint and it's correctly grounded, so check the voltage between the black and yellow wires with the ignition on.
Possibly faulty if the above is OK.
benelectrical
Copper - Posts: 59
Posted: August 18, 2012 at 11:22 AM / IP Logged
yeah that all should be fine all my grounds come from the same wire which i connect to a earth wires (not chassis)
yeah im guessing faulty module / diode
thanks
Posted: August 18, 2012 at 11:39 AM / IP Logged
"That should all be fine?" TEST!
And what diode?
benelectrical
Copper - Posts: 59
Posted: August 18, 2012 at 11:42 AM / IP Logged
the alarm wouldnt work at all if their was no earth
dont know what diode, but often alarms go faulty sort of the same problem i have.
the parkers or indicators what ever u connect stays on its caused by a diode
Posted: August 18, 2012 at 11:48 AM / IP Logged
You need to go to your earth to check the ignition.
That simple test will tell you everything, hence there's no point posting until you test.
Stop fumbling with the diode comment, only relevant as 2 x 1N5404s on the white indicator wire. Absolutely nothing to do with the alarm turning on.
Unless it's a faulty unit (very unlikely) it isn't seeing the ignition when ignition is turned on.
Don't expect any other answers until you've tested.
Please read my signature line it should be the first port of call for amateurs.
benelectrical
Copper - Posts: 59
Posted: August 18, 2012 at 11:59 AM / IP Logged
the answer to the problem is new brain/module. let u know when i get the replacement
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
