desperate to identify alarm module
mastertvtech
Posted: August 22, 2012 at 8:22 PM / IP Logged
Hey guys, I own a 2003 Corvette that has a GM dealer added alarm module.  I am desperate to identify it so that I can disable the auto arm which is making me nuts.  Two local shops had no clue but I did get a look at the module which actually works off of the factory fob.  The module I am told is DEI but has GM on it.  DEI was of no help so I am hoping some expert here has a programming sheet.  I may have to go to the dealership if all else fails.
91stt
Silver - Posts: 564
Posted: August 22, 2012 at 8:31 PM / IP Logged
Do you have a picture of it to help identify it?
Since it has GM on it and uses the factory remote, I am guessing it is a Code Alarm ROG-1 or ROG-2.
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
mastertvtech
Posted: August 22, 2012 at 8:53 PM / IP Logged
I think it may actually be a VSS2200 based on some pictures I found...If this unit is compatable with an 03 vette then I think I am there..Now to find the prg sheet somewhere..............
91stt
Silver - Posts: 564
Posted: August 23, 2012 at 10:23 PM / IP Logged
if the unit looks like the vss2200 than it is a dei unit. sorry but i do not have any info for that unit.
Mike M2
Platinum - Posts: 2,652
Posted: August 24, 2012 at 11:01 AM / IP Logged
I remember installing them years ago, same as the Automate 415A i think (DEI). Let me see if i can find out....
Mike M2
Tech Manager
CS Dealer Services
Mike M2
Posted: August 24, 2012 at 11:10 AM / IP Logged
< size=2 face=Arial>< size=2 face=Arial>
1. Open a door: < size=2 face=Arial>< size=2 face=Arial>The GREEN wire, H1/5, or the VIOLET, H1/7 must be connected.
2. Turn the ignition on, then off: < size=2 face=Arial>< size=2 face=Arial>The YELLOW wire, H1/9 must be connected.
4. Select a feature: < size=2 face=Arial>< size=2 face=Arial>Press and release the valet/program button the number of times corresponding
to the step you wish to change. For example, to access the third feature, press
and release three times. Then press the button once more and HOLD it. The siren will
chirp the number of times equal to the step you have accessed.
5. Program the feature: < size=2 face=Arial>< size=2 face=Arial>While holding the valet/program button, you can toggle the feature
on and off using your factory remote transmitter. Pressing the button that locks the doors
will select the one chirp or default setting. Pressing the button that unlocks the doors, will
select the two chirp setting.
NOTE: < size=2 face=Arial>< size=2 face=Arial>The valet pulse count feature (8) has five possible settings. Pressing unlock will
toggle through all the possible settings.
6. Release the valet/program button.
Step One Chirp (Default) Two Chirps
1 Active arming Passive arming
2 Audible arm/disarm confirmation on Audible Arm/disarm confirmation off
3 Siren duration 30 seconds 60 seconds
4 Instant door trigger Delayed door trigger
5 Door trigger error chirp ON Door trigger error chirp OFF
6 Sensor shunt zones 2 and 4 All zones
7 Panic enabled Auxiliary output enabled
8 No function No function
9 Valet switch input: 1 pulse Valet switch input: 2-5 pulses
Mike M2
Tech Manager
CS Dealer Services
mastertvtech
Posted: August 24, 2012 at 8:34 PM / IP Logged
If this works I will owe you big time!  I will try this first thing tomorrow.
Thanks for the research!
mastertvtech
Posted: August 25, 2012 at 9:27 AM / IP Logged
Done deal!  Thanks again....I won't even tell you how much a reputable shop wanted to toggle that off......
