2004 ninsan platina
gabe8405
Posted: September 10, 2012 at 3:54 PM / IP Logged
hey guys i need help im a pro installer but im in mexico i need help with this car ninsan platina cant find wiring diagrams for this car cause is not for usa but i need to do bypass to the transporter custumer lost  the key is a ninsan platina 2004 thanks
gabe
Platinum - Posts: 7,828
Posted: September 10, 2012 at 4:56 PM / IP Logged
Good luck.  Looks like it is a Renault Clio.  Might have to perform surgery on that last key...
Maybe Howard can give you the low down on Renaults...
Posted: September 10, 2012 at 5:37 PM / IP Logged
Definitely a Clio, the only quick and easy way round is if you have a second key, pull the RFI chip and mount it on the plastic antenna cowling around the ignition switch barrel.
Without that you're up a creek without a paddle even if your name is Valeo.
You aren't going to beat an 04 transponder wiring diagram or no, it's DATA not voltage.
Start being very nice to your local Renault/Nissan dealer.
You have an impossible task without one key.
