2012 infinity g37x remote start info
civicsi89
Posted: October 08, 2012 at 6:46 AM / IP Logged
I am in the need for 2012 g37x remote start wiring info. Thanks in advanced.
shortcircuit161
Silver - Posts: 556
Posted: October 08, 2012 at 7:07 AM / IP Logged
You will need a data bypass module for the immobilizer, push to start and door locks.
12volts      white (40A)      +      BCM, black 3 pin plug, pin 1
Notes: If equipped, the Satellite Radio Tuner is under the right rear deck (4 door), or in the right side of the trunk (2 door).
Starter      brown (push-button start)      -      push-button ignition switch or BCM, gray 40 pin plug, pin 29
Notes: The BCM (Body Control Module) is in the passenger kick.
Second Starter      red (sedan, coupe), brown (convertible)      -      BCM, gray 40 pin plug, pin 21
Ignition      lt. blue (sedan, coupe), red (convertible)      +      BCM, black 40 pin plug, pin 11
Second Ignition      yellow      -      BCM, gray 40 pin plug, pin 16
Third Ignition      N/A
Accessory      beige      +      BCM, black 40 pin plug, pin 31
Second Accessory      beige      +      BCM, black 40 pin plug, pin 24
Keysense      lt. blue      +      key slot or BCM, green 40 pin plug, pin 10
Power Lock      use factory alarm arm or insert pin      -      BCM, green 40 pin plug, pin 37
Power Unlock      use factory alarm disarm or insert pin      -      BCM, green 40 pin plug, pin 15
Lock Motor      purple      5 wire      BCM, white 16 pin plug, pin 5
Unlock Motor      green      5 wire      BCM, white 16 pin plug, pin 6
Parking Lights+      red      +      driver kick (w/DRL); dash fuse box, white 10 pin plug, pin 8 (w/o DRL)
Parking Lights-      N/A
Hazards      green      -      BCM, black 40 pin plug, pin 39
Turn Signal(L)      beige (F); yellow (R)      +      BCM, white 16 pin plug, pin 15; white 12 pin plug, pin 6
Turn Signal(R)      white (sedan, coupe), brown (conv) (F); purple (R)      +      BCM, white 16 pin plug, pin 14; white 12 pin plug, pin 1
Reverse Light      beige      +      driver kick, harness to rear or radio, white 32 pin plug, pin 19 or 21
Door Trigger      gray (sedan, coupe), red (convertible)      -      BCM, green 40 pin plug, pin 39
Dome Supervision      purple (dome lamp), lt. blue (step lamp)      -      BCM, white 16 pin plug, pins 16 and 4
Trunk/Hatch Pin      beige (sedan, coupe), green (convertible)      -      BCM, gray 40 pin plug, pin 19
Hood Pin      lt. green      -      hood switch or underhood fuse box, white 16 pin plug, pin 14
Trunk/Hatch Release      gray      -      BCM, gray 40 pin plug, pin 36
Power Sliding Door      N/A
Factory Alarm Arm      purple (sdn, cnv), gray (cpe) (driv door key lock)      -      power window main switch, white 16 pin plug, pin 4 or 6
Factory Alarm Disarm      yellow (sdn), white (cpe, cnv)(dr door key unlock)      double -      power window main switch, white 16 pin plug, pin 6 or 7
Disarm No Unlock      Intelligent Key and ignition
Tachometer      red (sedan, coupe), brown (convertible)      ac      Power Steering Cntrl Unit behind glove box, wht 12 pin plug, pin 10
Wait to start      N/A
Brake Wire      pink or brown      +      dash fuse box, wht 10 pin plg, pin 3 or BCM, grn 40 pin plug, pin 7
Parking Brake      beige (A/T); gray (sedan), purple (cpe, cnv) (M/T)      -      parking brake switch, white or black 1 pin plug, pin 1
Notes: Also found lt. blue (-) at the radio, white 32 pin plug, pin 18 or 5.
Horn Trigger      lt. green      -      horn switch, gray 8 pin plug, pin 8
Memory Seat 1      brown      -      Auto Drive Position Cntrl Unit right of column, wht 32 pin plug, pin 9
Memory Seat 2      purple      -      Auto Drive Position Cntrl Unit right of column, wht 32 pin plug, pin 25
Memory Seat 3      N/A      -
civicsi89
Posted: October 08, 2012 at 7:14 AM / IP Logged
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
