starter kill on 2009 dodge avenger
j_ffuri
Posted: October 08, 2012 at 4:01 PM / IP Logged
Hi I am a newbie here can someone help me , i all wired the connection from DBALL bypas to code alarm CA6552 using W2W, i need to know do i have to connect the starter kill relay and where in 2009 dodge avenger dodge avenger have designated starter kill wire according in wiring information
offroadzj
Gold - Posts: 2,043
Posted: October 08, 2012 at 9:26 PM / IP Logged
Starter      yellow/purple (for starter kill only)      +      driver fender, blk 20 pin plg, pin 12 (I-4); blk 14 pin plg, pin 6 (V6)
My own personal advice is to not even bother. Yes it is taking away some of the security feature, but if someone gets to that point, they will know how to bypass a simple starter kill and get your car anyway. But by cutting the factory wire you are opening the doors for issues down the road.. even with a perfect installation. That's just my personal opinion...
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
j_ffuri
Posted: October 21, 2012 at 9:42 PM / IP Logged
I already install the CA6552 to 2009 dodge avenger with DBALL bypass module using installation type 4, problem it has different wire color code ill just connect the other wire where it should be,the problem where do I connect the purple starter output of the CA6552 should be on pin 4 but it not available according to installation type 4 of DBALL, test the connection it just on but the starter not cranking please help me here
CONNCTOR IGNITON SWITCH / DBALL and CA6552
pin1- (-)black
pin2-    PURPLE / gray -----( 8:violet/green & 9:violet/ brown)multiplex
pin3- (+) pink -----------(ignition input/ ignition output)
pin4- vacant no wire " shoud be starter output"
pin5- (+)pink/ white
