dei: avistart 4000xl manual
06f150
Copper - Posts: 57
Posted: November 06, 2012 at 9:32 PM / IP Logged
Hello, Just picked up a 2006 Ford F350 6.0 with this installed on it.
DEI: Avistart 4000xl Install manual
Looking for the install manual on this unit.
When the remote starter is active, the parking lights do NOT turn on, I want to fix this.
So a install manual would be great or even if someone knew what wire this is off for the parking lights off the remote starter!
Thanks!
blanx218
Silver - Posts: 654
Posted: November 06, 2012 at 10:10 PM / IP Logged
The DEI website isnt working right now, but it should be white. It would have an inline fuse and should be connected to brown (+) parking light wire in the truck located at the back of the switch
06f150
Copper - Posts: 57
Posted: November 06, 2012 at 10:24 PM / IP Logged
Ok, That make sense...I have installed a few ultra remote starters and I recall now with what you said that they too where white wires with the inline fuse for the parking lights
I will take a look tomorrow, hopefully just the fuse! : )
Thanks for the memory Jog!
06f150
Copper - Posts: 57
Posted: November 14, 2012 at 9:21 PM / IP Logged
Turns out that the wire simply fell out of the push type plug connecter. Plugged it back in and all is good!
Not a fan of those any-who...The whole RS unit is connected like this :(
Like theses
dei: avistart 4000xl manual -- posted image.
I always solder. Maybe a project for this winter : )
Thanks again!
Posted: November 15, 2012 at 1:46 AM / IP Logged
Ouch, naughty, IDC's are a real no no!
We aren't even allowed to use them in the UK, vibration as in your case, corrosion etc.
