smartstart and db all
dustintinsley
Member - Posts: 17
Posted: November 24, 2012 at 10:34 AM / IP Logged
I have a db-all installed on my '12 Jeep Wrangler. It is working using the 3x lock on my OEM key fob. I am trying to hookup a VSM200 via D2D. I have the brown wire in the configuration loop cut and routed to a ground. The white wire is still connected. All I am receiving on the smartstart is a fast flashing amber led. what have i done wrong? i don't get any green led.
dustintinsley
Member - Posts: 17
Posted: November 24, 2012 at 2:05 PM / IP Logged
i can not figure this out. i can not get ANY green leds. anyone have any ideas?
lurch228
Silver - Posts: 1,338
Posted: November 24, 2012 at 5:05 PM / IP Logged
Sent PM
dustintinsley
Member - Posts: 17
Posted: November 24, 2012 at 6:09 PM / IP Logged
Ok. Below is what I have done so far.
This is what I have thus far. This is on a 2012 Jeep Wrangler Unlimited. Xpresskit DB-ALL connected via the CHTHD2 T-harness. Using the db-all as starter with the 3x oem key lock function. Db-all is flashed to latest firmware (5.01). Car starts/stops as expected using the 3x function so db-all is functioning. I am trying to connect a VSM200 via d2d. I verified that setting 1 on the db-all is set to smartstart (3 flashes). I have the y-harness connected to the smartstart. the white connector on the y-harness is plugged into the d2d connection on the smartstart. the brown wire in the config loop is cut and ran to a ground. all i get is fast flashing amber. no green lights and the amber light never goes steady.
lurch228
Posted: November 24, 2012 at 7:18 PM / IP Logged
Leave the brown loop un grounded, and power cycle the SmartStart.
dustintinsley
Member - Posts: 17
Posted: November 26, 2012 at 7:06 PM / IP Logged
Ok, I am attempting to build a add-on for my Xpresskit db-all using a gsm remote control relay. the information i need is what input/output does d2d expect? by this i mean, on my db-all, pin 1 is TX, and pin 3 is RX. So, what signal does pin 3 expect to initiate the start/stop command. any help would be appreciated...
lurch228
Posted: November 27, 2012 at 4:45 AM / IP Logged
I believe it is a DBI (Data Bus Interface) as the older protocol was SPI (Serial Presence Interface) but other than that I don't know what the commands are. As manufactures use there own version of the protocol's to comunicate with.
luniz7
Member - Posts: 18
Posted: March 05, 2013 at 2:03 PM / IP Logged
Did you ever get this to work properly? Im trying to do the same thing with the dball and the vsm200 connected d2d and get just rapid amber flashing light as well.
dustintinsley
Member - Posts: 17
Posted: March 11, 2013 at 7:40 PM / IP Logged
luniz: never got it working. did you have any success?
luniz7
Member - Posts: 18
Posted: March 14, 2013 at 8:35 PM / IP Logged
Nope. Gonna try and contact xpresskit and see what they can tell me.
