compustar, 98 pontiac sunfire
niceguywpg
Member - Posts: 7
Posted: November 27, 2012 at 12:17 PM / IP Logged
Hello I need help. I am installling a compustar CM6200 in a 1998 pontiac sunfire. Manual Transmission, I need to know how to by pass the clutch safety?
shortcircuit161
Silver - Posts: 556
Posted: November 27, 2012 at 3:31 PM / IP Logged
The clutch switch should have a violet colored wire that goes direct to the starter motor. Just attach the starter wire from the remote starter to that violet wire from the clutch switch.
When it's time for the CM6200 to remote start the car, it will engage the car starter directly thru that violet wire.
niceguywpg
Member - Posts: 7
Posted: November 27, 2012 at 10:01 PM / IP Logged
This is what the manual stats for this violet wire ------
Pin 19 Violet [POC 9] - Violet [POC 9] - Auxiliary 1 - 250mA negative (-) output. This is an optional output
that will provide a pulsed, latched, or timed negative output when triggered by the remote(s). This can
be used for power sliding doors, window modules or other outputs.
So your saying just correct this wire to the violet wire at the clutch?? Do I have to do any programing ??
Thank you
Posted: November 28, 2012 at 1:44 AM / IP Logged
No, that's for a second starter.
CN1 YELLOW.
niceguywpg
Member - Posts: 7
Posted: November 28, 2012 at 8:52 AM / IP Logged
I only want the clutch bypass to work
shortcircuit161
Silver - Posts: 556
Posted: November 28, 2012 at 9:01 AM / IP Logged
The clutch switch takes the starter wire from the ignition switch harness and cuts the connection when the clutch pedal isn't pressed in. At the clutch switch, there should be one wire that comes from the ignition switch harness and one that goes to the starter solenoid under the hood. When you press the clutch pedal in, it completes the circuit and allows the power to flow from the ignition switch to the starter. That is a high powered positive (+) wire. You cannot connect a low current (-) wire to the clutch switch wire as you can damage the remote starter. The violet wire I referred to is on the car at the clutch pedal switch.
As Howie stated above, you would use the Yellow wire on the CN1 harness of the Compustar, Yellow starter wire and connect it to the violet wire of the clutch switch, which goes to the starter directly.
As with everything else, use this info at your own risk and test everything first with a DMM.
niceguywpg
Member - Posts: 7
Posted: November 29, 2012 at 9:46 AM / IP Logged
I will try it tomorrow thanks
niceguywpg
Member - Posts: 7
Posted: December 02, 2012 at 7:14 PM / IP Logged
So, I got it working well kinda it fires up now but it stalls right away any ideas ??
shortcircuit161
Silver - Posts: 556
Posted: December 02, 2012 at 7:52 PM / IP Logged
Did you connect the tach wire and program the Compustar to learn the tach signal?
That car uses the Passlock anti-theft system. What bypass module are you using?
niceguywpg
Member - Posts: 7
Posted: December 03, 2012 at 5:07 AM / IP Logged
Yup all done
