viper 3303/python 333 door locks
osualum
Posted: August 12, 2013 at 5:27 PM / IP Logged
I've got a Python 333, which I think is the same as a Viper 3303. I'm installing this in my 64 Corvette. I've added the DEI 524N door lock actuators as this car does not have power locks. On the door lock harness I have:
H2/1 violet -- going to 12V
H2/2 blue/black -- to blue wires on 524N
H2/4 violet/black -- paired with H2/1 to 12V
H2/5 GREEN/ black -- to green wires on 524N
The alarm arms/disarms, but the actuators are not working. Am I missing something?
Platinum - Posts: 7,828
Posted: August 12, 2013 at 6:26 PM / IP Logged
Think you need to connect H2/3 and H2/6 to chassis ground.
On a Lock command, H2/5 will output a +12V signal to the 524N solenoid. The other side of the solenoid needs to be at
chassis ground to complete the circuit.   The reverse happens during a Unlock command, with H2/2 supplying the (+) and H2/5 giving the (-).
osualum
Posted: August 12, 2013 at 8:51 PM / IP Logged
Ah, that sounds like it might work. I'll take a look this weekend.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
