Posted: December 29, 2013 at 3:08 PM / IP Logged
Posted: December 29, 2013 at 4:08 PM / IP Logged
Posted: December 29, 2013 at 4:29 PM / IP Logged
Posted: December 29, 2013 at 5:28 PM / IP Logged
Posted: December 29, 2013 at 5:42 PM / IP Logged
Posted: December 30, 2013 at 6:55 AM / IP Logged
Posted: December 30, 2013 at 8:14 AM / IP Logged
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
So, with that said here is what I attempted and I will answer questions as well.
In the hookup process I thought I found the Red data wire going to a Black plastic piece around the ignition switch so I tapped that.
This left me unable to program the Fortin Bypass as it would never go past the first step of stopping on the yellow.
When I re-inserted the plugs and turned the key nothing happened, the light stayed yellow.
So I disconnected those wires and wired the Red wire back inline.
I then proceeded to fortin programming two.
This passed muster this morning and I thought I had it licked because that is when I got the van to start.
I did NOT pay attention to what was where when I started it properly so that is when I posted earlier.
I just tried to reset it again and was mostly unsuccessful.
I thought maybe I mis-programmed one of the fobs so I tried the second fob and it started........ but then I noticed I had the keys in the ignition.
I took the keys out and it went back to not starting.
So to start properly I MUST have the key in the ignition and in the ON position for it to remote start.
I am wondering now if the Fortin is either programmed incorrectly or has failed as this sounds more like the bypass is not working correctly or loose connection?
