compustar cm6200
bat9905
Copper - Posts: 131
Posted: January 15, 2014 at 6:07 PM / IP Logged
Could anybody please provide me with programming instructions. I need white horn ouput to sound horn on lock unlock and start . I plan to use valet switch for programming
bat9905
Platinum - Posts: 7,827
Posted: January 15, 2014 at 7:01 PM / IP Logged
While this Install Manual is for the CM6000 unit, there really isn't too much difference other than the added alarm functions.  Here is the link :
https://www.the12volt.com/installbay/file.asp?ID=1207
Look at Menu 3-08 for Horn options.  Programming instructions start on Page 35.  You need a multi-button remote to program the unit.  Can't help you too much with programming using the  remotes, I use the OP-500 programmer.
Wednesday, July 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
