locating horn wire on '96 grand am
patthehat033
Member - Posts: 18
Posted: January 18, 2014 at 1:42 AM / IP Logged
I need help locating the horn wire on my 96' Grand Am 3.1L SE.
It says it is a black wire in the steering column. I have the steering column covers off and the harnesses are exposed. There is a wire with a yellow thing on it, which is the air bag. There is one harness for each multi-function switch. There is a harness in the back. Lastly there is a plug with two wires coming out, white and black. Would the two wire one be the horn, or would it be in a normal harness with a bunch of wires probably?
I will do some testing with the multimeter, but narrowing it down would be easier. Thanks!
itsyuk
Silver - Posts: 505
Posted: January 18, 2014 at 2:51 AM / IP Logged
if you were to unbolt the electrical convenience center from (i believe) the firewall inside the car near the steering column, you will find your black wire on the backside of it where that black wire plugs into the horn relay.
holding a finger on each relay as you honk the horn will let you feel which relay is the horn relay.
that relay has a blk, org and dark green wire going to it.
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
patthehat033
Member - Posts: 18
Posted: January 18, 2014 at 2:55 AM / IP Logged
Can I tap in at the fuse box? Or is that 12V+?
patthehat033
Member - Posts: 18
Posted: January 18, 2014 at 6:10 PM / IP Logged
Okay I located that wire, now I need to locate the parking lights wire. There is a BROWN wire going into the relay for the turn signals that is coming out of the steering column harness, is this the correct wire?
itsyuk
Silver - Posts: 505
Posted: January 18, 2014 at 10:52 PM / IP Logged
have you been here?...
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
yuk
patthehat033
Member - Posts: 18
Posted: January 18, 2014 at 10:56 PM / IP Logged
Yes, I actually installed the remote start and the bypass and got them working. I just need to hook up the horn, parking lights, and door locks (with 451m).
That is misleading for the parking lights wire though, one says the steering column, and then the picture says the driver kick panel, however I didn't see anything in the kick panel, I might have to dig deeper. I was hoping the other wire I mentioned would work as an alternative.
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
