1999 suburban door locks
tc187211
Posted: January 19, 2014 at 7:48 PM / IP Logged
Installed a viper 4204v remote start and keyless unit. The door lock outputs are (-). I located the light blue and the white wire in the kick panel for the door locks.Question is, do I need a relay? Is there an option to make the (-) outputs become (+) outputs on the viper units? I have searched the forums all night and could not find anything directly related to my vehicle. Any help would really be appreciated. Hoping to not need a relay.
atish
Member - Posts: 25
Posted: January 19, 2014 at 7:57 PM / IP Logged
On most remote start units there is only a negative lock outputs so you will need to wire a relay or use a 451m or door lock relay module
chev104275
Gold - Posts: 1,436
Posted: January 19, 2014 at 8:02 PM / IP Logged
You will need 2 relays or a dei 451m to change the polarity to positive.
tc187211
Posted: January 21, 2014 at 9:34 PM / IP Logged
Thanks to you both. I will check out the wiring diagrams on the site here. I appreciate it.
tejarillo
Member - Posts: 21
Posted: January 26, 2014 at 8:35 PM / IP Logged
You will need 2 relays I just did mine on my Chevy Colorado and I had to use 2 relays.
https://img35.imageshack.us/img35/2607/powerdoorlockwiringfour.jpg
