1999 honda civic lx manual ct 3371
supeg
Posted: January 29, 2014 at 11:35 AM / IP Logged
Hello, currently having a bitch of a time getting this remote start/alarm set up for this Vehicle.
Currently have 12 hours setting this up and trying to fix these issues. Problem right now is Car does not seem to go into Ready mode.
1999 honda civic lx manual ct 3371 -- posted image.
Following these instructions, I turn on Car, put Ebrake on, press and hold one of the listed buttons and the Parking light remains lit and flashes for 3 seconds. I can then remove the key and the engine is running. I have the Door Pin grounded so it thinks doors are always shut so I hold down the Lock button for one second, it shuts down the engine but it does not do the last step
7. "The parking lights will flash twice to confirm ready mode activation"
Then if I try to start it I get one Light flash which says it is not in ready mode. Tried everything I could and not sure where to go from here.
Please help!
triniforever
Copper - Posts: 323
Posted: January 29, 2014 at 2:19 PM / IP Logged
Why do you have the door pin grounded ? The brain has to see the the door open and then closed to go into ready mode !
triniforever
supeg
Posted: January 29, 2014 at 3:09 PM / IP Logged
I think that might be the problem! I have +12 on it for testing, Ill connect it properly and try when i get home.
