2005 dakota u1120 code
emanuelb85
Member - Posts: 9
Posted: March 10, 2014 at 10:07 AM / IP Logged
Hi
I installed a viper 5706v remote start and alarm on my 2005 dodge dakota and after installing I keep on getting this u1120 code. Everything works fine with the alarm and starter. I'm thinking it's because when the truck is started not all the ignition components are on and maybe I missed an ignition wire or accessory wire that I should of hooked up. Thanks for the help.
chev104275
Gold - Posts: 1,436
Posted: March 10, 2014 at 12:26 PM / IP Logged
Did you power all the ignition and acc wires ?
Ignition      pink/lt. green      +      ignition harness
Second Ignition      pink      +      ignition harness
Accessory      dk. blue and pink/white      +      ignition harness
Second Accessory      pink / YELLOW (x2)      +      ignition harness
Keysense      PURPLE / tan      -      ignition harness
Also on these trucks of it has a factory alarm you will need to power keysense while remote started
emanuelb85
Member - Posts: 9
Posted: March 10, 2014 at 12:39 PM / IP Logged
For the ignition I only wired the pink light green wire.
chev104275
Gold - Posts: 1,436
Posted: March 10, 2014 at 12:46 PM / IP Logged
I would power up the rest. I always power all ignition wires the same as the key would
emanuelb85
Member - Posts: 9
Posted: March 10, 2014 at 12:52 PM / IP Logged
Yeah I think your right. Now the other ignition wires can I splice them to the same output on the alarm? And can I do the same to the accessory ones, can they be spliced to the same output on the alarm? I went off a bulldog security diagram and it said keysense was not available on this vehicle and that's why I didnt hook that one up.
chev104275
Gold - Posts: 1,436
Posted: March 10, 2014 at 1:03 PM / IP Logged
Never splice circuits together there separate for a reason. The Viper should have low current negative outputs to control relays to add more ignition and acc circuits to the remote start.
If you don't know how to wire the relay. check out the relay section on this site.
As far as key sense I believe it's only needed when the truck has a factory alarm. What will happen is the truck will start and run but while it's running the alarm will randomly go off.
Any other help don't hesitate to ask
emanuelb85
Member - Posts: 9
Posted: March 10, 2014 at 1:07 PM / IP Logged
What if I diode isolated them? Or is that not recommended.
chev104275
Gold - Posts: 1,436
Posted: March 10, 2014 at 1:11 PM / IP Logged
I wouldn't the ignition and acc are high current.
emanuelb85
Member - Posts: 9
Posted: March 10, 2014 at 1:50 PM / IP Logged
Thanks for the help. I'm going to do that and hopefully that does the trick.
emanuelb85
Member - Posts: 9
Posted: March 22, 2014 at 7:38 PM / IP Logged
Just wanted to give a quick update. After hooking up ALL the other ignition and accessory wires everything works great and I no longer get that engine error code.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
