'13 Nissan NV and '09 Chevy HHR wiring
Home /
the12volt's Install Bay /
Car Security and Convenience / '13 Nissan NV and '09 Chevy HHR wiring (
Topic Closed)
Welcome Guest :)
Posted: April 10, 2014 at 11:02 AM / IP Logged
Good Morning,
I am looking to see if anyone has the wiring information on two vehicles they can share. for remote start.
2013 nissan nv 1500/2500 van
2009 chevy HHR
any help is greatly appreciated
rnemtb
Posted: April 10, 2014 at 11:08 AM / IP Logged
2013 NISSAN NV1500 VAN WITH 4.0L ENGINE AND BASE-LEVEL AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery YELLOW (+) RADIO HARNESS
Accessory ORANGE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination BROWN (+) RADIO HARNESS
Dimmer VIOLET (+) RADIO HARNESS
LF Speaker (+) BLUE
LF Speaker (-) WHITE
RF Speaker (+) RED
RF Speaker (-) GREEN
Radio Security YES
Remote Start
Anti-Theft Type NISSAN NVIS® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
WIRING INFORMATION - NISSAN / NV / 2013 / Remote Start
12volts green (40A) + ignition switch, white 6 pin plug, pin 3
Starter yellow + ignition switch, white 6 pin plug, pin 2
Second Starter N/A
Ignition blue + ignition switch, white 6 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition switch, white 6 pin plug, pin 4
Second Accessory purple + ignition switch, white 6 pin plug, pin 5
Keysense brown + ignition key sw or BCM bhnd instr cluster, white 40 pin plug, pin 37
Power Lock gray - driver kick or BCM behind instr cluster, white 15 pin plug, pin 5
Power Unlock red - driver kick or BCM behind instr cluster, white 15 pin plug, pin 6
Lock Motor green 5 wire driver kick or BCM behind instr cluster, black 15 pin plug, pin 10
Unlock Motor white 5 wire driver kick or BCM behind instr cluster, black 15 pin plug, pin 4
Parking Lights+ red + driver kick, white 4 pin plug, pin 3
Parking Lights- N/A
Hazards orange - hazard switch or BCM behind instr cluster, white 40 pin plug, pin 29
Turn Signal(L) yellow + driver kick or BCM behind instr cluster, black 15 pin plug, pin 5
Turn Signal(R) green + passenger kick or BCM behind instr cluster, black 15 pin plug, pin 6
Reverse Light orange + driver kick, white 4 pin plug, pin 4
Door Trigger lt. blue - driver kick or BCM behind instr cluster, white 15 pin plug, pin 7
Dome Supervision blue - driver A pillar or BCM behind instr cluster, black 15 pin plug, pin 8
Trunk/Hatch Pin gray (right back door upper) - driver A pillar or BCM behind instr cluster, white 40 pin plug, pin 13
Hood Pin N/A
Trunk/Hatch Release locks/unlocks along with doors
Power Sliding Door N/A
Factory Alarm Arm lt. blue (driver door key lock) - driver kick or BCM behind instr cluster, white 40 pin plug, pin 8
Factory Alarm Disarm yellow (driver door key unlock) double - driver kick or BCM behind instr cluster, white 40 pin plug, pin 7
Disarm No Unlock see factory alarm disarm
Tachometer NOT white or WHITE/ green ac any fuel injector
Wait to start N/A
Brake Wire lt. green + driver kick, white 4 pin plug, pin 2 or BCM, white 40 pin plug, pin 9
Parking Brake green - parking brake switch, black 1 pin plug, pin 1
Horn Trigger white - driver kick, white 16 pin plug, pin 14
2009 CHEVROLET HHR 4DR SUV SS WITH 2.0L T/C ENGINE AND PIONEER® AUDIO SYSTEM
Audio/Mobile Video
Battery RED / WHITE (+) RADIO HARNESS
Accessory
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
Ground BLACK/ WHITE (-) RADIO HARNESS
Power Antenna PINK (+) RADIO HARNESS
THIS WIRE TURNS ON THE ANTENNA AMPLIFIER UNIT.
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
THESE WIRES PROVIDE THE AUDIO SIGNAL TO THE AMPLIFIER
LF Speaker (-) DARK GREEN
RF Speaker (+) LIGHT GREEN / WHITE
RF Speaker (-) LIGHT GREEN
LR Speaker (+) BROWN
LR Speaker (-) BROWNWHITE
RR Speaker (+) DARK BLUE
RR Speaker (-) TAN
Amp Location LOCATED BEHIND TRIM IN LEFT SIDE OF CARGO AREA.
THE AMPLIFIER IS ATTACHED TO THE SUBWOOFER ASSEMBLY
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
Security
Battery RED / BLACK (+) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Ignition 1 YELLOW (+) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Starter 1
THIS VEHICLE STARTS WHEN IGNTION POWER IS APPLIED AND ACCESSORY POWER IS LOST,
All Door Trigger GRAY (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
LF Latch GRAY/BLACK (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
RF Latch TAN/BLACK (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Trunk Trigger PINK/BLACK (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Hood Trigger PINK/BLACK (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Alarm Disarm SEE NOTES
WILL DISARM WHEN THE VEHICLE SEES IGNITION 1 AND THE PASSLOCK AT THE SAME TIME.
Parking Lights BROWN (+) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Low Crr Pk Lights BROWN / WHITE (-) AT VEHICLE LIGHT SWITCH
Convenience
Headlights-Lo WHITE (-) AT VEHICLE LIGHT SWITCH
LF Pk Lt Bulb BROWN (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb BROWN (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb BROWN (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb BROWN (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights WHITE (-) AT VEHICLE HAZARD SWITCH
Wipers-Lo DARK GREEN (+) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Parking Brake LIGHT BLUE (-) AT VEHICLE PARKING BRAKE SWITCH
ALSO AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Trnk Release WHITE/ BLACK (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Remote Start
Accessory 1 BROWN (+) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Starter 1
Anti-Theft Type GM PASSLOCK II® ANTI-THEFT SYSTEM
Anti-Theft Descript THE BCM MODULE MUST SEE A SPECIFIC RESISTANCE VALUE BEFORE THE VEHICLE WILL START PROPERLY
Tachometer TAN (AC) AT ECM MODULE NEAR DRIVER STRUT TOWER
Speed Sense LIGHT BLUE (AC) AT EBCM MODULE IN FRONT OF UNDER HOOD FUSE/RELAY BOX
Low Crr. Pk Lights BROWN / WHITE (-) AT VEHICLE LIGHT SWITCH
Brake Lights LIGHT BLUE (+) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
ALSO AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights LIGHT GREEN (+) IN HARNESS IN PASSENGER KICKPANEL
Horn TAN (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
Rear Defrost LIGHT BLUE (-) A/C CONTROL UNIT IN DASH
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
USE A 1.5K OHM RESISTOR FOR UNLOCK- *SEE DOCUMENTS *ON VEHICLES WITHOUT FACTORY KEYLESS ENTRY, DATA MODULES WILL NOT CONTROL THE DOOR LOCKS.
PowerLock WHITE (-) AT BCM MODULE AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
LOCK IS (-) TRIGGER, SAME WIRE FOR UNLOCK
Driver Mtr Unlock TAN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Driver Mtr Lock GRAY (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LF Window Up DARK BLUE (REV) AT POWER WINDOW SWITCH
LF Window Dn BROWN (REV) AT POWER WINDOW SWITCH
RF Window Up DARK BLUE (REV) AT POWER WINDOW SWITCH
RF Window Dn BROWN (REV) AT POWER WINDOW SWITCH
LR Window Up DARK GREEN (REV) AT POWER WINDOW SWITCH
LR Window Dn VIOLET (REV) AT POWER WINDOW SWITCH
RR Window Up LIGHT GREEN (REV) AT POWER WINDOW SWITCH
RR Window Dn VIOLET (REV) AT POWER WINDOW SWITCH~wirewise~
Posted: April 14, 2014 at 7:20 AM / IP Logged
Thank you for the info it is greatly appreciated
rnemtb
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
