dome light and door triggers.
paradox_108
Member - Posts: 48
Posted: June 24, 2014 at 6:27 PM / IP Logged
Hi Guys
Ive previously did a viper 5901 on a Honda delsol now its a manual transmission everything works but to put the car into manual remote start mode ill have to do the usual manual shutdown sequence.
now this car has neg door triggers that are link to the dome lights and my sister really needed dome light supervision. So I hooked everything but I cant put it into manual start mode until the 30sec domelight supervision has gone out.
Is there a work around for this?
djrico724
Member - Posts: 40
Posted: June 24, 2014 at 10:44 PM / IP Logged
Only thing I can think of is to relay isolate the dome light. So what you are going to do is grab dome light wire right at light cut it and put relay in line. Now done light is no longer wired with door triggers
paradox_108
Member - Posts: 48
Posted: June 25, 2014 at 1:28 AM / IP Logged
yeah i was thinking that it might be the only way... I'm surprised that no one else ran into the same problem
