add door lock switches
todd5.0
Posted: June 24, 2014 at 9:19 PM / IP Logged
I installed an Avital 3100L alarm to my 2002 Ranger truck. I added the 451M door lock relay module to the alarm box. I installed the factory Ford 2 wire power door lock latches and 3 wire door switches. I wired the Ford door lock actuators using the wiring diagram for Reverse polarity actuators. It works perfectly with the Avital alarm and remotes.
I want to wire in the factory Ford door switches to this system.
Can I use the 5 wire alternating 12 volt positive door lock diagram without a separate power source to the door switches ?
What is the best way to wire them in ?
Todd5.0
djrico724
Member - Posts: 40
Posted: June 24, 2014 at 10:23 PM / IP Logged
I would use negative polarity to operate the switches. So one of the 3 wires on switch will goto ground and the other to lock and unlock from alarm make sure to diode isolate so you don't feed into alarm brain
todd5.0
Posted: June 25, 2014 at 12:03 AM / IP Logged
djrico724 thank you for the reply. I don't work on electronics all the time so I am not following you with the diode isolate. Is there a diagram that you can point me to for the reverse polarity ?
Todd5.0
Posted: June 25, 2014 at 11:19 AM / IP Logged
Diode bands away from alarm, use 1N4004 diodes.
Tuesday, August 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
