manual needed for ford remote start
1klw
Member - Posts: 22
Posted: July 15, 2014 at 8:27 PM / IP Logged
Ford motor company remote starter/entry combo,looking for wiring and programming manual.its a ford aftermarket piece 5button remote,some shop installed it and they told him there is no light flash out in this model,remote start the vechicle,unlock get in insert key turn it 1before start hit the brake truck shut off.bad install no solder or tie straps.
chev104275
Gold - Posts: 1,436
Posted: July 15, 2014 at 9:20 PM / IP Logged
Go to techservices.codesystems.com it's free to sign up and they have the Ford stuff on there. As far as light flash it's the white wire coming from the middle harness. Polarity is set under the DNA chip panel on the main module.
1klw
Member - Posts: 22
Posted: July 16, 2014 at 1:51 PM / IP Logged
thank you I will give it a try.manual needed for ford remote start -- posted image.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
