vw transporter tdi
sonkus
Posted: August 19, 2014 at 4:33 AM / IP Logged
I need to add aftermarket central locking system to my VW transporter TDi car. I want to find a way to wire the system. The factory built system failed. Could anyone out there help me with the original system circuit? If possible please let me have the security system circuit for the same car
Hustler
Posted: August 20, 2014 at 6:10 AM / IP Logged
What year?
sonkus
Posted: August 27, 2014 at 12:03 PM / IP Logged
2007 model
Hustler
Posted: August 27, 2014 at 12:11 PM / IP Logged
It's a nightmare! The original motors are part of the door lock behind an aluminium panel that also holds the window motors/winder mechanism and glass.
You can either add motors between the inner door panel and the aluminium and join to the lock rods or better still get it repaired. Have you checked all the fuses with a multimeter?
sonkus
Posted: August 27, 2014 at 3:09 PM / IP Logged
Done all the basic electrical checks including fuses, socket connectors ground terminals but no good results.
Hustler
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
