remote start not working 02 caravan
aray176
Member - Posts: 6
Posted: October 27, 2014 at 7:36 PM / IP Logged
Hi. Installed excalibur Rs 330 e in my van and it doesnt start it. The keyless entry feature works fine. Did the relays with resistors. I think my problem is the secondary start wire. (Purple and brown) i cant seem to set it right. Please help. No signs of life at all. No clicking or anything.
soundnsecurity
Gold - Posts: 2,720
Posted: October 27, 2014 at 7:45 PM / IP Logged
if you are getting no response at all from the excalibur then its probably because you havent finished programming it or there is a remote start shut down trigger that is active when you are trying yo remote start.
aray176
Member - Posts: 6
Posted: October 27, 2014 at 7:51 PM / IP Logged
The keyless entry feature is working so system is working but im dead in water with actual remote start. I wired all necessary wires
catback
Silver - Posts: 703
Posted: October 28, 2014 at 10:33 AM / IP Logged
If you can't do a "pit-stop" you need to check find out why, whether it be wiring, programming, or sensor/triggers. I also noticed no mention of transponder bypass.
aray176
Member - Posts: 6
Posted: October 28, 2014 at 11:16 AM / IP Logged
It's a regular key. No transponder.
aray176
Member - Posts: 6
Posted: October 28, 2014 at 4:18 PM / IP Logged
Hey i just performed a pit stop. It worked fine. So what can my problem be?
catback
Silver - Posts: 703
Posted: October 29, 2014 at 1:18 AM / IP Logged
The secondary start wire has to be grounded through a 180 ohm resistor during the crank of the remote starter. Use a relay to accomplish this.
List your connections if the above isn't the issue.
aray176
Member - Posts: 6
Posted: October 29, 2014 at 6:05 AM / IP Logged
Thank you. Finally got it working fine.
catback
Silver - Posts: 703
Posted: October 29, 2014 at 9:15 AM / IP Logged
What fixed it?
And man does that van take alot of relays with all the multiplexed wires.
aray176
Member - Posts: 6
Posted: October 29, 2014 at 9:29 AM / IP Logged
I finally found a negative pulse from remote start to power my relay for starter 2 wire. And yes, have done Remote starts before but nothing like this van. Headache
