viper 4105 brain red light flashing
richco
Member - Posts: 21
Posted: November 13, 2014 at 11:16 PM / IP Logged
Hi All,
I just install viper 4105 one way remote starter on my 2001 dodge diesel automatic,truck start ok but parking light and horn does not come on, i have connect parking and horn wires,the red light is blinking regularly on the brain and does not allow me to go in programing mode please help me how I can reprogram this one, does this red light is ok to blink or I have done something wrong please help me.
Mark Mizenko
Copper - Posts: 460
Posted: November 14, 2014 at 11:07 PM / IP Logged
Press unlock on the remote. The system s locked/armed
richco
Member - Posts: 21
Posted: November 14, 2014 at 11:34 PM / IP Logged
Thanks for reply I will try it tomorrow then let you know hope will work.
richco
Member - Posts: 21
Posted: November 15, 2014 at 11:38 PM / IP Logged
Thanks,
 I follow how you said it work fine now no blinking light but I cannot programme manu2, opt3, feature10, which is time delay for 30 second when i try first 2 places it honk the horn twice but when I do the third time it honks 2 time but last honk get longer and it does not doanything no programe.
My another issue is the parking lights I have hook up main harness no 9 white wire(+/-,light flash output) to truck BLACK / YELLOW(+) at headlight switch, when I remote start the truck it start ok but parking lights does not come on please help me to solve this problem.
Platinum - Posts: 7,828
Posted: November 16, 2014 at 8:47 PM / IP Logged
Did you check the setting of the Viper 4105V's Parking Light jumper on the side of the controller next to the Red 4 Pin D2D port.  It should be in the "+" position.
richco
Member - Posts: 21
Posted: November 16, 2014 at 9:54 PM / IP Logged
thanks for reply, no I have not checked it I will check it tomorrow, for the engine delay I tryed to program it but it does not go after 2nd option, should I use delay relay for it.
Posted: November 17, 2014 at 5:05 AM / IP Logged
I use a BitWriter, so it's very easy to change any option.  On the Diesel Wait to Start feature, Menu 2, Item 10, the BitWriter gives second by second increments up to 90 seconds...
richco
Member - Posts: 21
Posted: November 17, 2014 at 10:16 PM / IP Logged
Thanks for reply, the jumper was taped to the RS module it installed it on the module as directed, I have removed the transfer case from the truck for rebuild will be done tonight I will give you update tomorrow.
richco
Member - Posts: 21
Posted: November 18, 2014 at 8:30 PM / IP Logged
Thanks a lot for helping me every thing work good no flashing light my first installation done with the help from kreg357,please keep teaching junior members thanks again.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
