viper 5706v and idatalink connections
daytontd
Member - Posts: 23
Posted: December 28, 2014 at 6:06 PM / IP Logged
This is for a 2004 Silverado
I am confused about the Ignition (+) Input on the idatalink sheet. This is the only last connection it says I have to make from the remote starter to the idatalink.
My problem is that all I have on the 24 pin connection that is close on the Viper 5706 is the(17)PINK (-) 200mA IGNITION 1 OUTPUT. The idatalink however calls for a (+) IGNITION 1 OUTPUT (Remote starter side) to a (+) IGNITION 1 INPUT (Idatalink side).
Can I connect a - (from the viper) to a + on the module? If not what do I do? Convert it somehow with a relay although this seems like it would be too much current for the module. Or just leave disconnected since I am still wiring the the viper direct to the truck.
vane0804
Member - Posts: 40
Posted: December 28, 2014 at 6:13 PM / IP Logged
Which IDatalink are you using? what version? firmware? wiring schematic?
~It's me!
vane0804
Member - Posts: 40
Posted: December 28, 2014 at 6:20 PM / IP Logged
Looking closer at your explanation...forget that (-) ignition output from your viper remote start...use the heavy guage Pink (+) Ignition output from Viper remote starter to (+) IGNITION 1 INPUT (Idatalink side).
~It's me!
daytontd
Member - Posts: 23
Sorry it is an ADS-AL CA. I bought it together with the Viper alarm from a car electronics place, they said they flashed the idatalink with the necessary information.
Here is the viper:
Viper Install
idatalink
Go to page 7 of 9
daytontd
Member - Posts: 23
Posted: December 28, 2014 at 6:22 PM / IP Logged
I was looking at this but worried that it will fry the module since that wire is pretty thick.
Platinum - Posts: 7,828
Posted: December 28, 2014 at 6:28 PM / IP Logged
You will connect the Viper H3 Pink (+) Ignition 1 Output wire to both the Silverado ( Pink @ main ignition harness ) and the iDatalink Pink (+) Ignition Input wire.  Like this W2W mode connection below ( Ultra Start U1272 R/S ) :
viper 5706v and idatalink connections -- posted image.
vane0804
Member - Posts: 40
Posted: December 28, 2014 at 6:29 PM / IP Logged
no...you won't fry the module..that's where it goes..bypass moduel always has smaller guage wires.
~It's me!
daytontd
Member - Posts: 23
Posted: December 28, 2014 at 6:33 PM / IP Logged
Okay awesome thanks. Since I am use the DTD connection all I should connect on the idatalink is the pink wire (ignition), orange (data), and purple (tach) correct?
Posted: December 28, 2014 at 6:42 PM / IP Logged
Well...
If you are running in D2D mode between the ADS AL-CA and the Viper 5706v, you must flash the bypass module with the DBI AL(DL)-GM1 flavor of firmware and follow this install guide  :  http://cdncontent2.idatalink.com/corporate/Content/Manuals/DL-GM1/DBI-AL(DL)-GM1_20111004.pdf
There are only two wires from the ADS AL-CA that will be hardwired, the Pink and the Orange.  Everything else should be handled by the D2D harness.
tedmond
Gold - Posts: 4,610
Posted: December 28, 2014 at 6:56 PM / IP Logged
Kreg at it again with spot on answers. No wonder he's platinum, and I'm only gold ;)
Ted
Compustar Expert
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
