Pit Stop Mode with a 551t?
davep.
Gold - Posts: 649
Posted: February 10, 2015 at 3:41 AM / IP Logged
I can't think of an easy way to bench test a 551T without hooking it to an actual engine to get a tach signal. So can any of you remember this about a 551T? I'll probably test anyway, but am what-if-ing.
If you trigger the 551T on the wht/blu activate wire on an already-running engine:
A: Will it activate, or does it fail because tach signal is present?.
B: If it does activate, does it run the starter on an already running engine?
I like pit-stop mode, and use it frequently on my other vehicles that have more sophisticated systems. I'm curious if the 551T can be made to pit-stop too. I have a work-around for "B" in the above. For "A", I guess get a newer unit. :grin:.
Thanks as always.
tedmond
Gold - Posts: 4,610
Posted: February 10, 2015 at 6:34 AM / IP Logged
all DEI products can be programmed for "assume running" - this is good on the one touch start vehicles. Look in programming and find engine checking off. that way it will start on a bench and wont shutoff.
If i recall correctly, pit-stop works fine, but of course you can go over this on a bench
Ted
Compustar Expert
davep.
Gold - Posts: 649
Posted: February 10, 2015 at 7:19 PM / IP Logged
Thanks Ted.
The 551T isn't very sophisticated. I put it in "Voltage Check". It would stay on.
I simulated a "pit stop": R/S activate > key on > brake input defeat > activate > key off (unit remained activated until time-out).
With the simulated engine running (B+ present on yellow wire at relay satellite), it activated, but did NOT activate the starter output. Which is what one expects for "pit stop".
The only thing I don't like is that the minimum time-out period is 12 minutes. Later DEI's, the pit-stop run-time can be programmed for less than the R/S run-time.
Now I know what to expect after it is installed. There's no substitute for testing. Thanks again.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 13, 2015 at 6:36 AM / IP Logged
I'm pretty sure it'll work fine for pit-stop mode.
What are you using to activate the 551T? A doorlock motor wire in the car? An existing aftermarket alarm?
A few issues I could see are:
---Whatever you're going to use to activate the 551T, does it still function when your car engine is running?
---Whatever method you currently use to lock the doors in your car, does that work with the engine running? If not, keep in mind that if you make a pit stop, and desire to lock the car, you'd have to lock the doors manually.
A few years back, I had a 1994 Caprice wagon. There was a "trip reset" button on the dash, which made a negative output. If you held the button in for a few seconds, it would reset the trip odometer.
Anyway, I tied my remote starter's activation input to the wire coming from the switch. When I parked, I could hit the button very quickly, and the remote starter would enter pit-stop mode, but the trip meter would not reset, since I didn't hold the button in too long.
Depending on what car you have, you might be able to do the same. If your power mirror switch has a center detent that makes the buttons not move either of the mirrors, you could tap into one of the mirror button wires for this.
davep.
Gold - Posts: 649
Posted: February 13, 2015 at 8:16 PM / IP Logged
QUOTE=Chris Luongo:
>>> It does. The owner's guide doesn't mention pit-stop, but it does it using the wht/blu activate wire.
What are you using to activate the 551T? A door lock motor wire in the car? An existing aftermarket alarm?
>>> Aftermarket alarm. An old DEI 350, I'll use the RED / wht Aux 2. This is a pick-up. I don't need hatch-pop. Plus Aux 2 requires a 3-second hold the button down. Perfect for R/S activation.
>>>This is what has prompted me to use the old 350. I've had this 1991 S-series truck for 18 years. I installed a factory RKE from a 93 S-Blazer when I first got it. I was going to use the hatch-pop I've never needed to activate the 551. But the factory RKE does not activate the hatch with the ignition on. And I want pit-stop. Yes, I could hide a button for the wht/blu wire, and rely on the brake-defeat if a joyrider found it, but I don't think I want to do that.
>>> I'll test the 350 for this. I've had this all set up on the bench, but I don't remember if the 350 cares if the IGN is on or not for the locks, if it isn't programmed for IGN-contrrolled lock or unlock. I don't think it does.
---A few years back, I had a 1994 Caprice wagon. There was a "trip reset" button on the dash, which made a negative output. If you held the button in for a few seconds, it would reset the trip odometer.
---Anyway, I tied my remote starter's activation input to the wire coming from the switch. When I parked, I could hit the button very quickly, and the remote starter would enter pit-stop mode, but the trip meter would not reset, since I didn't hold the button in too long.
>>> This is neat thinking. I like it a lot. I do a lot of passive-arm ghost switches. I've never thought of using the trip computer buttons. Thanks for the tip.
>>> I'm an old-school guy, the truck is old, the equipment is old, it's all a perfect fit. I will test the 350's lock outputs with the IGN on, but I think that too will be fine. Or I'll lock it manually, which I do now anyway.
I appreciate the comments and input. I learned some stuff.
Thanks.
