2011 Nissan Altima PTS, Compustar CM7200
tianot
Copper - Posts: 155
Posted: February 22, 2015 at 4:39 PM / IP Logged
hey guys! i installed a compustar cm7200 remote starter using a fortin evo all bypass. remote starter is working fine except that the heater won't turn on.
the altima is a 3.5l engine with a auto climate control. when the car is manually start the heater won't on. it will turn on only when you press the heater switch button.
how can i make the heater turn on when the car is remote started?
thanks
tianot
mpe235
Copper - Posts: 90
Posted: February 22, 2015 at 5:08 PM / IP Logged
thanks
Check to make sure the storage fuse is pushed in. It is in the fuse box inside the car to left of the steering column. It is a white square. Just push on it.
Nissan Master Tech.
tianot
Copper - Posts: 155
Posted: February 22, 2015 at 7:25 PM / IP Logged
thanks mpe235. it fix the problem
tianot
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
