Viper 5706       2014 Camry regular key ignition        EVO-ALL flashed with DBI 6.79.25
Main Harness, 6-pin connector
1 RED (+)12VDC CONSTANT INPUT       GREEN (+)  @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 5
2 BLACK (-) CHASSIS GROUND             Chassis Ground
3 BROWN (+) SIREN OUTPUT                Viper siren
4 WHITE/ BROWN PARKING LIGHT ISOLATION - PIN 87a     not used
5 WHITE PARKING LIGHT OUTPUT   *** Set to (-)        BLACK (-)  @ 20 Pin Headlight Switch Plug
6 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT      not used
Door Lock, 3-pin connector
1 BLUE (-) 500mA UNLOCK OUTPUT          Via D2D
2 EMPTY NOT USED
3 GREEN (-) 500mA LOCK OUTPUT            Via D2D
Remote Start, 10-pin heavy gauge connector
1 NC No Connection
2 RED / BLACK (+) FUSED 12V ACC/STARTER INPUT    GREEN (+)  @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 5
3 PINK/BLACK (+) FLEX RELAY INPUT 87A      not used
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT          PINK (+)  @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 1  * set to IGN2
5 RED (+) FUSED 12V IGNITION 1 INPUT         GREEN (+)  @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 5
6 GREEN (+) STARTER INPUT (KEY SIDE)       BLUE (+) @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 7
7 VIOLET (+) STARTER OUTPUT (CAR SIDE)     BLUE (+) @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 7
8 ORANGE (+) ACCESSORY OUTPUT              not used - according to EVO-ALL diagram
9 RED / WHITE (+) FUSED 12V IGNITION 2        GREEN (+)  @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 5
10 PINK (+) IGNITION 1 INPUT/OUTPUT           BLACK (+)  @ IGNITION SWITCH HARNESS, WHITE 8-PIN PLUG, PIN 6
Auxiliary/Shutdown/Trigger Harness, 24-pin connector
1 PNK/WHITE (-) 200mA Ignition 2/Flex OUTPUT      not used
2 BLUE/WHITE (-) 200mA 2ND STATUS /REAR DEFOG      not used
3 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT          Via D2D
4 BLACK / YELLOW (-) 200mA DOME LIGHT OUTPUT          not used
5 DARK BLUE (-) 200mA STATUS OUTPUT     to EVO-ALL A8
6 WHITE/ BLACK (-) 200mA AUX 3 OUTPUT     not used
7 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT      not used
8 ORANGE / BLACK (-) 200mA AUX 4 OUTPUT           not used
9 GRAY (-) HOOD PIN INPUT (NC OR NO)      Via D2D if vehicle has factory hood pin
10 BLUE (-) TRUNK PIN (N/C OR N/O)             Via D2D
11 WHITE/ BLUE ACTIVATION INPUT              not used
12 VIOLET/WHITE* TACHOMETER INPUT     Via D2D
13 BLACK/ WHITE** (-) NEUTRAL SAFETY     Via D2D
14 GREEN/ BLACK (-) 200mA FACTORY ALARM DISARM  Via D2D
15 GREEN* (-) DOOR INPUT                Via D2D
16 BROWN / BLACK (-) 200mA HORN HONK OUTPUT         optional
17 PINK (-) 200mA IGNITION 1 OUTPUT        not used
18 VIOLET* (+) DOOR INPUT               not used
19 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT          not used
20 BROWN (+) BRAKE SHUTDOWN INPUT     Via D2D
21 VIOLET / YELLOW (-) 200mA STARTER OUTPUT   to Pin 85 of external relay
22 GRAY/BLACK (-) DIESEL WAIT TO START INPUT         not used
23 ORANGE (-) 200mA ACCESSORY OUTPUT        not used
24 GREEN / WHITE (-) 200mA FACTORY ALARM ARM        Via D2D
Extra 30/40 Amp SPDT relay
Relay Pin 85 to Viper 21 VIOLET / YELLOW (-) 200mA STARTER OUTPUT
Relay Pins 86 and 87 to Yellow @ Pin 4 of Ignition Switch Harness through 7.5 Amp fuse
Relay Pin 30 to  lt. green  +  ignition switch, white 8 pin plug, pin 3
Relay Pin 87a not used - insulate
Better yet, for all the +12V constant power connections, look for a very thick Black wire at the front of the fuse box.
