2000 Cherokee locks .
mystic122468
Posted: May 29, 2015 at 7:26 AM / IP Logged Link to Post Post Reply Quote mystic122468
Hi guys, I'm just finishing up wiring up a remote start and i'm having a heck of a time with the power door locks.
I've got one wire showing a Negative Pulse and the other showing 12V and Negative when the button is pressed. The negative is easy BUT the other is like a 5 wire, Do I have to go into the door with a Relay between the switch and lock motor?
Is there an easy way?
Any help would be great, Thanks!
2000 Jeep Cherokee Sport
chev104275
Gold - Posts: 1,436
Posted: May 29, 2015 at 8:32 AM / IP Logged Link to Post Post Reply Quote chev104275
JEEP / CHEROKEE /Sport/2000 / Remote Start
Power Lock      ORANGE / purple       -      drivers kick panel
Notes: Must use relays to trigger the lock and unlock wires. Close all doors when testing.
Power Unlock      pink/purple       -      drivers kick panel
mystic122468
Posted: May 29, 2015 at 8:38 AM / IP Logged Link to Post Post Reply Quote mystic122468
Thanks, I have the colors and the correct wires, my question was how to wire the relay correctly.
Posted: May 29, 2015 at 10:33 AM / IP Logged Link to Post Post Reply Quote howie ll
Cut the lock and unlock wires.
R/Start lock and unlock,assume NEG (-) outputs.
Lock to 85,12V+constant 86,both relays 2 amp fuse.
Good ground to 87.
Switch side of vehicle wires to 87a
Other side to 30.
Diode 1N4004 to coil, band side to 86.
Switch side? That's the cut side that shows a (-) NEG when you switch to either lock or unlock.
mystic122468
Posted: May 29, 2015 at 10:43 AM / IP Logged Link to Post Post Reply Quote mystic122468
thanks! i'll give that a try
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
