Remote Start Keeps Starting and Shuts Off
solano_79
Member - Posts: 8
Posted: May 30, 2015 at 10:29 AM / IP Logged Link to Post Post Reply Quote solano_79
Hello,
I need some help. I am unable to troubleshoot this problem. I would appreciate your insight.
My remote start will attempt to start the vehicle at random. The vehicle engine will crank but fail to run. I believe the system is shutting it back down.
I have no issues starting the vehicle with the remote. If I activate remote start via the remote the car starts and continuous running.
I removed the batteries from the two remotes and the issue has not gone away. The car still attempts to start at random. I do not believe it is timer based or temperature based. I do not see a pattern with time or temperature or believe my system is that smart.
My system:
--4105V Viper
--PLJX ByPass Module
--451m Lock Module
Vehicle:
--2000 Chevy Silverado 2500 6.0L
I installed the system myself and can share schematics if this will help. Have any of you ran into this issue? Any recommendations?
Thanks!
Edgar
Everyone wants tomorrow today...
Posted: May 30, 2015 at 11:43 AM / IP Logged Link to Post Post Reply Quote howie ll
The WHITE/ blue wire on H2, is this going to ground?
Antenna fault? Check lead.
solano_79
Member - Posts: 8
Posted: June 03, 2015 at 2:29 PM / IP Logged Link to Post Post Reply Quote solano_79
Thanks for the response. I will take a look at that this weekend.
Edgar
Monday, October 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
