2015 Nissan Rogue Rap shut down
mpe235
Copper - Posts: 90
Posted: July 05, 2015 at 11:58 AM / IP Logged Link to Post Post Reply Quote mpe235
I installed a crime stopper RS2-G3 and evo-all in my 2015 Nissan Rogue. It has a regular key. Everything works as it should except the rap shutdown. I connected everything according to the evo-all instructions. The light blue wire is going to the driver's door pin wire at the bcm. If i test the wire with a meter it does not ground after shutdown. I also tried connecting the orange wire from the remote start to that pin instead. I configured option 12 to arm after remote start abort but I still don't get a ground on that wire. I did test the wire at the bcm also. I definitely have the correct wire there. Any ideas on what i could be missing? I don't see anything in the evo-all options that would change the function of that wire. I am using firmware 72.19.
Nissan Master Tech.
mpe235
Copper - Posts: 90
Posted: July 08, 2015 at 4:59 PM / IP Logged Link to Post Post Reply Quote mpe235
Just in case anyone runs into this problem, it is an issue with firmware 72.19. 72.18 works fine.
Nissan Master Tech.
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
