yet another LED install question
rayray780
Posted: May 24, 2003 at 10:54 PM / IP Logged
hey everyone...
this is my first post here in the forum.  i purchased 2 blue LEDs that i am placing on each front door (by the window controls).  i would like to have them light up when my car alarm is armed (ON).  i cut off the little red LED that came with my PolarStart alarm/starter.  i hooked up the red wire of the new LEDs to a constant power and the black wire i hooked up to the accessory wire that went to the original red LED that i cut off.
(Varad LED instructions)
yet another LED install question -- posted image.
the new LEDs light up fine when i turn on the alarm.  but when it's off i can see some faint blue flckering coming from them.  i do not know where this residual activity is coming from.
should i try to use another accessory wire?  which one should i use on the alarm?  i know that i can just hook them up throught the ignition and have the LED's go on when the car is off... but i'd specifically like the LEDs to light up when the alarm is actually armed.  there is the yellow wire coming from the LED that i can also use.  here is a wiring schematic of my alarm.  i circled the wires that i'm currently using.  i know that i'm not hooking this up right.  some please edjumakate me.  =)
thanks for the help.
-rayray
CutDog504
Silver - Posts: 643
Posted: May 25, 2003 at 12:15 AM / IP Logged
Try cutting the ground off of that led accessory wire, and try connecting it to the sarter kill output wire(WHITE/ yellow accoring to your diagram) But you will need a 1amp diode to do this. Tap into this wire with the ground from your leds and install the diode between this point and the starter kill relay. Make sure that the band side of the diode faces the end of the wire towards the alarm and not the side with the starter kill relay.
rayray780
Posted: May 25, 2003 at 10:09 PM / IP Logged
well... i decided to just wire them in series using the basic POWER/GROUND/IGNITTION hook up that turns them on then i start the car.  the problem that i'm having now is that the LED's don't fully light up right away.  it sort of "st-st-stutters" before giving a full glow.  is it the way i wired it up?  i checked all the connections and they are all good.  i'm going off my wires on the back of my deck.  this happens when the radio is on or off, doesn't matter.
help?
thanks.
-ray
MielGibson
Copper - Posts: 74
Posted: May 26, 2003 at 2:32 PM / IP Logged
Are these 12v blinking LEDs?
rayray780
Posted: May 26, 2003 at 7:08 PM / IP Logged
yes.... these are 2 flashing blue LED's from Varad.
-rayray
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
