2009 Smart ForTwo Remote Start
sparxx513
Copper - Posts: 56
Posted: November 30, 2015 at 12:59 PM / IP Logged Link to Post Post Reply Quote sparxx513
Anyone have a diagram for one of these, has factory anti theft installed also.
thanks
chev104275
Gold - Posts: 1,436
Posted: November 30, 2015 at 1:28 PM / IP Logged Link to Post Post Reply Quote chev104275
DIRECTWIRE™ WIRING INFORMATION - SMART / FORTWO / 2009 / Remote Start
12volts red (50A) + dash fuse box, rear, black 3 pin plug, pin 3
Starter purple + dash fuse box, rear, white 2 pin plug, pin 1
Ignition RED / black + dash fuse box, rear, black 2 pin plug, pin 1
Second Ignition RED / blue + dash fuse box, rear, black 2 pin plug, pin 2
Power Lock pink (relay isolate from switch) - power lock switch or dash fuse box, rear, white 40 pin plug, pin 12
Power Unlock BLACK/ blue - power lock switch or dash fuse box, rear, white 40 pin plug, pin 16
Lock Motor gray / YELLOW 5 wire dash fuse box, rear, brown 8 pin plug, pin 4
Unlock Motor pink 5 wire dash fuse box, rear, brown 8 pin plug, pin 5
Parking Lights+ gray/blue + headlight switch or dash fuse box, rear, black 40 pin plug, pin 10
Hazards PURPLE / blue - hazards switch or dash fuse box, rear, black 40 pin plug, pin 31
Turn Signal(L) BLACK/ white + dash fuse box, rear, white 40 pin plug, pin 1
Turn Signal(R) BLACK/ green + dash fuse box, rear, white 40 pin plug, pin 11
Reverse Light yellow/red + left rear taillight, black 6 pin plug, pin 4
Door Trigger yellow/white - dash fuse box, rear, black 40 pin plug, pin 4
Dome Supervision BROWN / blue - dash fuse box, rear, white 40 pin plug, pin 4
Trunk/Hatch Pin blue/black - dash fuse box, rear, black 40 pin plug, pin 2
Trunk/Hatch Release pink / YELLOW (rear handle switch) - dash fuse box, rear, black 40 pin plug, pin 36
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (transponder and ignition)
Tachometer yellow/blue, purple, or pink ac any fuel injector, gray 2 pin plug, pin 1
Brake Wire BLACK/ red + driver kick, harness to rear
Parking Brake BROWN / black - parking brake switch, 2 pin plug, pin 1
Horn Trigger blue + dash fuse box, rear, brown 8 pin plug, pin 6
warning
sparxx513
Copper - Posts: 56
Posted: November 30, 2015 at 4:47 PM / IP Logged Link to Post Post Reply Quote sparxx513
Thank you, do you have a bypass you would recommend for the remote starting?
ak609
Member - Posts: 47
Posted: November 30, 2015 at 7:29 PM / IP Logged Link to Post Post Reply Quote ak609
it looks like DEI or IDATALINK do not make a bypass module for this vechile. You could check FORTIN but i have not used a fortin bypass module myself so i could not give you any feed back on them.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
