Voltage latching switch
enoxos
Member - Posts: 34
Posted: January 13, 2016 at 9:17 PM / IP Logged Link to Post Post Reply Quote enoxos
hello everyone,
I would like to make a voltage switch that opens (OFF) the circuit when the voltage drops below 10.5 Volts and stay on the OFF position regardless on whether the voltage goes above 10.5 Volts again. I should be able to reset it with a reset bottom. Is there anything like that either ready made or a schematic that I can put to use?
thanks
tonanzith
Gold - Posts: 603
Posted: May 22, 2016 at 7:24 PM / IP Logged Link to Post Post Reply Quote tonanzith
honestly i would look into using an arduino/raspberry pi. it would allow programming the parameters that your looking for. not a novice venture but the first thing that comes to mind and would definitely work.
Gary Sather
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
