Trunk Release diagram for european Yaris 2009
gammarco
Posted: January 14, 2016 at 10:57 AM / IP Logged Link to Post Post Reply Quote gammarco
Hello everyone,
I recently installed a custom trunk release system in my Yaris Sol hatchback. Here you can see the scheme of the installation (I think I connected the relay upside down, but it works anyway)
Trunk Release diagram for european Yaris 2009 -- posted image.
I would like to know how can I use 2 consecutive negative pulses from the remote control key to activate the relay of the trunk release?
1 pulse from the remote control unlocks all doors (this is factory default).
I think the solution might be in this diagram but since I'm a newbie I don't know how to use it in my situation.
I appriciate your suggestions, thanks.
Marco
geepherder
Platinum - Posts: 3,668
Posted: January 14, 2016 at 3:38 PM / IP Logged Link to Post Post Reply Quote geepherder
If this is all you want, a simple keyless entry system with an auxiliary output or trunk pop would do this for you. Then you'd just carry that remote instead of your factory remote.
For a little more, you could get an alarm or remote start.
Platinum - Posts: 7,827
Posted: January 14, 2016 at 5:56 PM / IP Logged Link to Post Post Reply Quote kreg357
You could use a PAC TR-7 module to do this.  Using Feature 14 wiring and programming, you could have the Green (+)
Input wire connected to the Drivers Door Unlock Motor wire.  Program the TR-7 to 2 input pulses within 3 seconds to give
an output.  Connect the Blue (+) output wire to the wire at Relay Pin 85.  *
Here is a link to the PAC TR-7 manual  :  https://www.the12volt.com/installbay/file.asp?ID=1031
Here in the States a PAC TR-7 module goes for $15.  As Mr. Geepherder said, it might be just as easy to get a
aftermarket Remote Start with Keyless Entry system for $50 and have it all on one remote.
* Standard relay convention is Relay Pin 85 gets a (-) input and Relay Pin 86 gets the (+) input.  Your diagram will work
  as long as the relay is not polarity sensitive ( internal coil quenching diode ).
Posted: January 15, 2016 at 4:31 AM / IP Logged Link to Post Post Reply Quote howie ll
Kreg, very few Euro alarms have aux outputs which is why I've been using Clifford from the 80's!!
Our OP might be able to use a Chinese fleabay for that money but I'll say no more.
All the Yaris models, alarms are so easy.
gammarco
Posted: January 15, 2016 at 5:37 AM / IP Logged Link to Post Post Reply Quote gammarco
Thanks everyone for the very quick answers!Trunk Release diagram for european Yaris 2009 -- posted image.
Although using an aftermarket remote is the easiest way I would like to find a solution to keep using the toyota remote, and the PAC TR-7 module do exactly what I want, thanks Kreg.
I took also a quick look at Clifford's website, if I'll have to install an aftermarket remote I consider these products.
I search a lot the web about my issue, do you think that this diagram can help in my case?
gammarco
Posted: February 21, 2016 at 2:43 AM / IP Logged Link to Post Post Reply Quote gammarco
Hi Kreg, I finally received the TR-7 from the States and installed on my Yaris according to your instructions.
It works perfectly! Thank you very much.
Here you can see it in action: YARIS HATCH POPPING
Thursday, January 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
