Alternative tracker/pager
is200_turbo
Copper - Posts: 88
Posted: February 01, 2016 at 3:37 PM / IP Logged Link to Post Post Reply Quote is200_turbo
So I used to have and install the clifford callguard units however a unit has failed so now looking for something similar
Any suggestions
is200_turbo
Copper - Posts: 88
Posted: February 02, 2016 at 9:17 AM / IP Logged Link to Post Post Reply Quote is200_turbo
Anyone ?
dosoft
Member - Posts: 30
Posted: February 02, 2016 at 8:27 PM / IP Logged Link to Post Post Reply Quote dosoft
Nothing similar is available on the market. You need to replace it with newer one like DEI's Smart Start. If you're very lucky it might be compatible with your Clifford via D2D.
figureitout
Member - Posts: 23
Posted: February 03, 2016 at 10:10 PM / IP Logged Link to Post Post Reply Quote figureitout
Just briefly checking out the Clifford callguard, I believe there's a unit that's similar, with some drawbacks. The main con is that it has only one output, negative, and can only be toggled on and off by sms, no other programming is possible.It has, if I remember, 4 separate input alerts which can be turned on or off individually or all together.
is200_turbo
Copper - Posts: 88
Posted: February 07, 2016 at 3:29 AM / IP Logged Link to Post Post Reply Quote is200_turbo
Do you have details on that unit
The callguard was perfect with the features it had just a shame one has packed up now
figureitout
Member - Posts: 23
Posted: February 08, 2016 at 5:53 PM / IP Logged Link to Post Post Reply Quote figureitout
I messaged you with some details.
