2007 nissan xterra X remote start/alarm clifford
wyciwug
Copper - Posts: 158
Posted: March 08, 2016 at 1:39 PM / IP Logged Link to Post Post Reply Quote wyciwug
Alarm/remote start Clifford 3.3X and XK07
I am installing the system for my Xterra. Here are the connections. If anything is wrong, please help me to correct it. Thanks members.
H1 12-pin
red 12v to constant 12volt in car
brown to siren
black to chassis ground
white parking to Gray in car at driver kick
H2 8-pin
BROWN / black to horn switch in car.
RS in 5-pin
BLACK/ white neutral safety to ground
violet/white tach to any fuel injector NOT WHITE/ green wire
Brown brake shut down to yellow in car at brake pedal switch
Gray hood pin switch to hood switch
Relay out 5-pin
Blue RS status to brown on XK07 bypass
Door lock/unlock PIN
Blue - Unlock to RED / white factory alarm disarm in car
Green - Lock to lt blue factory alarm arm in car
H1 Heavy Gauge wires
RED / white fused 30a + Red 12v fused 30am + RED / black fused 30a grouped to 12volts green in car 40a @ ignition switch
Pink to white green in ignition switch in car
Orange to accessory Red at ign switch in car
Pink/white to Green Yellow at ign switch in car
Violet to car side of starter wire (Gray wire at ignition harness cut)
Green to key side of starter wire (Gray wire at ignition harness cut)
Pink/black to second starter Lt Green at ignition switch??????
By pass XK07 (flashed)
I will use D2D connection
Brown from Xk07 to Blue RS status from Clifford
Red from XK07 to 12volt source
Black from XK07 to ground.
I know there are errors in here that's why I need help from any members. Thank you so much!
dcd
smokeman1
Platinum - Posts: 1,589
Posted: March 08, 2016 at 1:54 PM / IP Logged Link to Post Post Reply Quote smokeman1
Does your Xterra have a factory alarm?
Does your Clifford have a 24 or 18 pin harness? Or a 5 pin and 8 Pin.
Not sure what happened to the other post.
wyciwug
Copper - Posts: 158
Posted: March 08, 2016 at 1:57 PM / IP Logged Link to Post Post Reply Quote wyciwug
It does not hav factory alarm and i only have panic button. Plus its a 5-pin one.
dcd
smokeman1
Posted: March 08, 2016 at 2:25 PM / IP Logged Link to Post Post Reply Quote smokeman1
H3/2, H3/6, & H3/9 to 12 Volts constant>>>>Looks Good
H3/4, and H3/5 Looks Good
H3/1 Looks Good
H3/3 Looks Good
H3/7 Pink/White, I would use as a second Accessory to the GREEN / WHITE
Menu 3, Item 8, Option 2 to change from Ignition to Accessory
Pink/Black Not used
For your second starter, I would use the Violet (-) 200mA to pin 85 of a relay, Pins 87 and 86, fused to a constant 12volt, and Pin 30 out to your second starter wire, Light Green. Diode across pins 85 and 86, Band toward the 86 pin.
Lock wire to Purple in DKP
Unlock to Light Green in DKP
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
wyciwug
Copper - Posts: 158
Posted: March 08, 2016 at 2:37 PM / IP Logged Link to Post Post Reply Quote wyciwug
Thanks!
dcd
smokeman1
Posted: March 08, 2016 at 3:02 PM / IP Logged Link to Post Post Reply Quote smokeman1
All look good from the Clifford to the Xterra.
Don't forget to program for Automatic, if Automatic.
Menu 3, Item 1, Option 2
Never used a XK07, but if you are using D2D, I read it as it ONLY covers the 12volts , Ground, and Status. To me, I read it as you will still need to W2W the Can High(4), Can Low(5), Security LED( 6 & 7), and Ignition(8)
Listed on page 5 of the XK07 guide is a D2D or W2W by each wire.
Pay attention as to which side 6 & 7 connect to the Security LED wire as it is cut, BCM side and Car side.
You could try just the D2D connection. See if it programs. Maybe another forum member has some experience with the XK07.
It's just my read on the wiring of it.
wyciwug
Copper - Posts: 158
Posted: March 08, 2016 at 3:05 PM / IP Logged Link to Post Post Reply Quote wyciwug
I will try D2D, if it does not work, I will wire the rest as a w2w no problem. Thanks
dcd
smokeman1
Posted: March 08, 2016 at 3:10 PM / IP Logged Link to Post Post Reply Quote smokeman1
You didn't say what the XK07 was flashed with but I was reading the PKN3 Firmware Guide. Just so we are on the same page/guide
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
