DEI 507m Tilt Sensor issues
periziv22
Member - Posts: 10
Posted: May 28, 2016 at 3:42 PM / IP Logged Link to Post Post Reply Quote periziv22
Hello,
I installed a DEI 507m tilt sensor on my truck and fallow the instruction carefully.
*the blue wire is connected to the instant trigger and diode insulated
*the orange wire is connected to ground when armed and also diode insulated
*the red wire gets 12V 1 Amp constant.
about 10 second after arming the alarm, the sensor sets off the alarm.
does anyone have idea what is wrong?
Ziv22
periziv22
Member - Posts: 10
Posted: May 28, 2016 at 3:43 PM / IP Logged Link to Post Post Reply Quote periziv22
2000 Durango V8 4.7L
Ziv22
Posted: May 29, 2016 at 4:30 AM / IP Logged Link to Post Post Reply Quote howie ll
Leave out the diode to orange unless it's fulfilling another function.
Two diodes on the blue instant trigger if it's being used, also bands on diodes away from alarm.
periziv22
Member - Posts: 10
Posted: May 29, 2016 at 9:45 AM / IP Logged Link to Post Post Reply Quote periziv22
Thanks for your replay,
I do have other functions on the AWG wire so i have to leave the diode (bends facing the alarm)
now, you say that i should add another diode on the blue line going from the tilt sensor to the alarm with the bend facing the tilt sensor?
Ziv22
Posted: May 29, 2016 at 9:48 AM / IP Logged Link to Post Post Reply Quote howie ll
All the bands should face AWAY from the alarm. Diodes are required to separate the signals.
If that blue wire fulfils another function, say trunk trigger, then use a diode. If not no diode required.
periziv22
Member - Posts: 10
Posted: May 29, 2016 at 9:54 AM / IP Logged Link to Post Post Reply Quote periziv22
There is already diode on the blue wire that goes from the sensor to the alarm (facing away)there is other functions on the blue wire and they all diode insulated....
this is why i cant understand why the tilt sensor sets off the alarm 10 seconds after arming.
Ziv22
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
