2005 honda odyssey rear defrost wire location
jimmy317
Member - Posts: 7
Posted: June 27, 2016 at 10:20 PM / IP Logged Link to Post Post Reply Quote jimmy317
Can anyone tell me where is the rear defrost wire to connect to viper 5706v rear defroster output for 2005 honda odyssey touring
Jimmy
tonanzith
Gold - Posts: 603
Posted: June 27, 2016 at 11:00 PM / IP Logged Link to Post Post Reply Quote tonanzith
2005 honda odyssey rear defrost wire location -- posted image.
Gary Sather
jimmy317
Member - Posts: 7
Posted: June 28, 2016 at 2:15 AM / IP Logged Link to Post Post Reply Quote jimmy317
Thank you for replying. Correct me if I am wrong. On the diagram, the defogger wire is BLACK / YELLOW. Should I run the Blue/White "(-) 200mA 2ND STATUS /REAR DEFOGGER OUTPUT" to that wire directly or do I need to connect through a relay?
Jimmy
davep.
Gold - Posts: 649
Posted: June 29, 2016 at 1:55 AM / IP Logged Link to Post Post Reply Quote davep.
You can not connect blu/wht directly to the grid. You will need a relay.
I would try to find "E16 (not used)" on the underhood fuse block. If you find it, and it is vacant, with the key on, ground E16. The defogger should turn on. Check the grid with a VOM. If this tests OK, run the blu/wht rear defog output directly to E16. Check that the bl/wht wire is programmed to defog output, and not "Status".
In the paragraph above, you would be using the factory defog relay, power source, and fusing. Makes for a clean install with no added components or fuses.
jimmy317
Member - Posts: 7
Posted: June 30, 2016 at 8:08 AM / IP Logged Link to Post Post Reply Quote jimmy317
I could not locate the "E16" that you mentioned. Can you please post a picture?
