2001 Sierra 2500
ziggyb222
Silver - Posts: 593
Posted: October 08, 2016 at 6:50 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Installed a Avital 4103 in a GMC Sierra. Done a ton of these... In remote start and with the key.... the ABS and Brake light come on after about 20 seconds of running...Ignition wires timing?????
beegbie
Copper - Posts: 341
Posted: October 08, 2016 at 7:51 PM / IP Logged Link to Post Post Reply Quote beegbie
Did you power up the correct accessory? Should only need one along with two ignitions. I've heard that both accessories may need to be powered up but never experienced it myself.
ziggyb222
Silver - Posts: 593
Posted: October 08, 2016 at 9:49 PM / IP Logged Link to Post Post Reply Quote ziggyb222
I dont think I have ever powered up the brown acc. wire...
lurch228
Silver - Posts: 1,338
Posted: October 09, 2016 at 1:43 AM / IP Logged Link to Post Post Reply Quote lurch228
It's having this issue with the key also?
ziggyb222
Silver - Posts: 593
Posted: October 09, 2016 at 7:47 AM / IP Logged Link to Post Post Reply Quote ziggyb222
Yes when started with the key also. going to look at it again today...Everything is soldered also...
ziggyb222
Silver - Posts: 593
Posted: October 09, 2016 at 9:57 AM / IP Logged Link to Post Post Reply Quote ziggyb222
Found the issue...Appears to have been a cold soldered joint on the primary ignition wire... Resoldered it and checked all other connections and works as it should now....Thanks for your responses!!!!
lurch228
Posted: October 09, 2016 at 5:55 PM / IP Logged Link to Post Post Reply Quote lurch228
Did the Ignition wire get cut, as a bad soldered tie wont usually case this with the key?
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
