Viper 5101 in 2003 Mazda MPV
johnsnow
Posted: October 31, 2016 at 7:30 PM / IP Logged Link to Post Post Reply Quote johnsnow
The battery died and the techs just removed it without having a secondary power source so it looks like everything got reset including the radio.
I was looking at the viper menu and tried switching from virtual tack to voltage and also adjusted the crank time but it has not solved my problem.
The issue is the car will start and within 3 seconds it will die then start again another 2 times. Yes the engine starts but does not stay on.
I checked the diagnostic and got 4 LED flashes which means Transmitter shutdown (or optional push button) according to the manual.
Anyone know how i can resolve this myself?
johnsnow
Posted: November 03, 2016 at 7:56 PM / IP Logged Link to Post Post Reply Quote johnsnow
Anyone?
geepherder
Platinum - Posts: 3,668
Posted: November 03, 2016 at 11:26 PM / IP Logged Link to Post Post Reply Quote geepherder
I've reset my units by unplugging the harnesses and shorting the pins that connect to battery power and ground. This sometimes clears up unexplained hiccups.
